Service column lock.....again!
Hello everyone.
For the 2nd time in 5 months, I`m having to tow my vette into a dealer for column lock issues. 52,000 fairly problem free miles and now this. So I suppose I have to fork over money for another towing bill. Yesterday it was running fine and today this. Seems quite sudden. Is there anything I can check before having it towed. Battery is new and on charger.:willy: |
You can try to forcefully jerk the steering wheel left and right until it unlocks. I did that at a car auction with a c5 once and it worked.
you need to have the lock replaced. i had mine towed 3 times (under warranty) before they finally changed the lock. havent had any problems in 3 years.
I have been currently having this problem with mine, there are 2 ways to get it started.
1. If the message center says “service column lock” I can usually take the load off the wheel (and locking pin) and then push the start button at the same time and the car will start. 2. Sometimes the wheel does not lock and the car does not start, I get no message on the information center and the battery voltage is fine. When this happens I disconnect the positive battery cable, touch it to the negative cable for 10 second, then reconnect it. This clears out / resets everything and the car starts. You may need to cycle the switch twice to get it to start, but usually when you reconnect the battery, you hear the lock motor cycle and the car will start on the first try. |
Originally Posted by RICH 28
(Post 1571007799)
Mine does it every time the car sits out in the sun for a while and the interior gets warm. Jerking around the steering wheel gets it going every time. I'm going to order the part and take it in (module has to be programmed) when I get a chance.
This weekend I removed the outer section of the locking ring for the column lock in hopes that the solenoid locking pin would not bind up, unfortunately this morning I had to do the battery disconnect trick to start the car. Battery voltage was at 12.66v after sitting in the garage all night. I will post pictures of my modifications when I get home, apparently it did not fix anything but at least it will give everyone a visual of the column lock.
Originally Posted by Paratrooper307
(Post 1571009214)
Got it! Rattled the steering wheel back and forth and she gave in. I`m thinkin the cars been sitting to long in the garage. Maybe if there is any lube on the lock its getting gummy? I don`t know. This was fixed before. And the car does not get driven much lately.
Thanks guys for the input |
Glad it worked out for ya.
Originally Posted by 1988Bullitt
(Post 1571009301)
What price did you get on the module? The local dealer here (Kenny Kent Chevrolet, Evansville IN) stated $430 for the part. I did not know that it had to be programmed, I was hoping it was plug and play:toetap:
It's 148 bucks from Gene if I recall. I was hoping it was plug and play too, as you have to disassemble the dash to get at it, which is labor intensive. A buddy of mine is a chevrolet tech and he said because it's part of the antitheft system, it has to be "'set up" with the car, much like the radio. http://www.gmpartshouseusa.com/partl...layCatalogid=0 |
I cannot believe this is still a problem; GM Engineer's=worthless
Originally Posted by Trpblk04
(Post 1571013847)
(Post 1571012469)
(Post 1571009247)
Before, http://i223.photobucket.com/albums/d.../C6/column.jpg After, http://i223.photobucket.com/albums/d...C6/column1.jpg |
Originally Posted by RushThruLife
(Post 1571012318)
Thanks guys for the input Good to hear you did not have to tow it, I have been able to get mine to start everytime, just have to do the steering wheel wiggle or the battery disconnect dance:willy: |
(Post 1571007718)
Hello everyone.
(Post 1571014640)
Here's the modification I thought would help:
Before, http://i223.photobucket.com/albums/d.../C6/column.jpg After, http://i223.photobucket.com/albums/d...C6/column1.jpg That's good stuff. Unfortunately, with the majority of failures on the 2005, its seems as though the problem is not the pin getting stuck, its the module that controls it that ends up on the fritz. |
Originally Posted by Batmbl
(Post 1571015129)
Just curious: is this happening on all C6's or just manuals, or just autos. Really thought I was rid of this problem after selling my C5. Have not seen it yet on the C6.:toetap:
(Post 1571017397)
On C6's my understanding is it's just the 2005 manual transmission cars.
