C 4 Fuel Pickup Problem on Track
I know I have seen step by step instructions dealing with C 4 fuel pickup issues. The solution was to gently bend the in tank pick up tube. Can anyone send me a link to that thread?
Thanks |
Is this why my C4 with less than 1/2 tank of gas sometimes stumbles in corners?
Originally Posted by Kubs
(Post 1571041554)
Yes. This could be the source of your problem. Over the years, others have commented about it. When just below a half tank, and I turn left on high G turns, on either a sharp turn or a sweeping turn, I sputter. The problem is temporarily resolved by pulling into the paddock and fueling up. The proper fix is to bend the pick up tube into a different position.
Originally Posted by Z07coupe
(Post 1571041744)
The fix-it thread is in this forum. I have tried numerous terms in search, but can't seem to locate it. Give it a try.
My car did the same thing and after I bent the tube I could run until the reserve fuel light came on. The fix works like a charm.:thumbs:
Go to:
http://forums.corvetteforum.com/auto...-gas-tank.html This is the thread. 96CollectorSport had the answer back then, too. Thanks |
The cheapest and easiest thing is to just fill your car up after each session.
Richard Newton |
(Post 1571042259)
Go to:
Very true. But it looks like I may be working on my fuel pump, so while I'm there, I can easily correct this problem. (BTW, My tow hook performed admirably last Monday). |
(Post 1571042259)
Go to:
The sock should rest on the bottom, check if it does when you go to bend the assembly. Mine won't stutter till I'm into the bottom two bars, reserve light. I don't like to run over 1/2 tank because of all that extra weight. The stock tank is so long, I was thinking of putting fuel cell foam around the pick up spot.
The only time you have too much fuel is when you're on fire!
Bob |
I also have this problem and can't go below 1/2 tank. I tried bending my pickup tube but that hasn't seemed to help much. I saw something that Melrose T-Top had a bolt in 'cage' to hold a fuel cell in the stock location, but I haven't been able to find any information about it.
Originally Posted by Mojave
(Post 1571051616)
Could you share that info with us when you find it? |
(Post 1571053685)
:iagree::thumbs: |
Originally Posted by Kanmer
(Post 1571050380)
Bob |
(Post 1571053685)
Originally Posted by jwt1603
(Post 1571056104)
:iagree::thumbs:
From this page: http://tccracing.com//joomla//index....d=42&Itemid=99 Melrose T-Top offers a nice unit that will bolt in where the existing rear bumper was. This is a complete setup including the cell, the mounting bracket / bumper, fuel filter, and all the hoses and fittings for around $1500. http://www.tccracing.com/melrose.htm |
