**Attn Light Cannon Owners** Upgrade to version 2.0!!
Going on feedback from the first generation of light cannon headlights, I decided to re-design one of the key componets of the lights. In a projector headlight, the cutoff shield is what produces the pattern associated with high-end optics. While the shields in the light cannons did the job of limiting vertical output, I did see room for improvement.
The biggest concern was the fading cutoff on the edges. This is caused by the flat cutoff shield in the projector. Light bouncing off the reflector bowl hits the shield at different distances resulting in a faded cutoff. By curving the shield away from the reflector, the cutoff is sharpened and the projector produces a wider pattern. The second concern was long distance viewing. The wide "step" of the hella modules limits the intensity of the hot-spot at the center of the pattern. Modifying the step to be narrower and taller gives exceptional down-road vision without causing exceessive glare to oncoming traffic. Picture data: All pictures were using the same projector, bulb and camera. 6000K 35w HID, Canon SD990. This is the output of the original light cannons (~15ft) http://i606.photobucket.com/albums/t.../IMG_0957a.jpg And with the modified shield installed: http://i606.photobucket.com/albums/t.../IMG_0959a.jpg More pictures of the output: Distance: ~30' http://i606.photobucket.com/albums/t...s/IMG_0961.jpg Distance: ~50' (on fence to show width) http://i606.photobucket.com/albums/t...s/IMG_0963.jpg Those of you with light cannons can swap out your flat cutoff shields for the custom curved ones. Each shield is waterjet cut for consistant precision, hand bent and tested for accuracy. In addition, I'm also offering the 55w Slim ballast kits included with the Light Cannon 2.0. The 55w kits offer ~50% more output thatn the 35w counterparts: Here's a side-by-side comparison i pulled from another site: http://i606.photobucket.com/albums/t...on55w3copy.jpg Order the Complete Light cannon 2.0 upgrade Kit: $130 shipped In order to get this discount on the 55w HID kits, I need to have 10 orders or more. Lets get started. :cheers: |
Must say after upgrading to to the 55w kit it's definitely an improvement at night! You will not be disappointed after the upgrade!
i also moved to a 55watt low beam and a moved from 6000k to 4300k way more light....
Thanks, George. So let me get this right - for 130 bucks we get a new pair of cutoff shields, 2 slim 55w ballasts and 2 4300k bulbs? I presume the new ballasts will connect to my LC v1.0 wiring harness too? :lurk:
George,
I was thinking you sold me the new 2.0 light cannons, but my light patterns match the 1.0 version. Which did you actually sell me? |
Originally Posted by csdunaway
(Post 1571641458)
George,
Originally Posted by TheDVS1
(Post 1571641046)
3000K - golden yellow (excellent for fog and rain) 4300K - OEM white 6000K - white with hint of blue (most popular) 8000K - iceberg blue 12000K - bluish purple Please note that the color of 55w Kits will be about 500K lower in appearance than the 35w counterparts due to the additional wattage. If you ordered an additional HID kit (highs or fogs) You can upgrade those to 55w as well for an additional $100 per kit. |
Put me on the list for the new upgrade then!
Official "2.0 upgrade" list:
1. Csdunaway |
Ok, I'm in but to clarify, please bear with me;
If I have 5000K bulbs, will I need to use new bulbs? If I can keep the 5000K bulbs I have, the new 55W ballast will then drop the output to around 4500K AND be a bit brighter? If so, EXCELLENT! To summarize, I'll get; 1. New cutoff shields with instructions on how to change them 2. New ballasts which will increase my light output to 55W AND lower the Kelvin to around 4500K |
Originally Posted by TheRadioFlyer
(Post 1571642007)
Please note that the color of 55w Kits will be about 500K lower in appearance than the 35w counterparts due to the additional wattage. . i'm interested in the upgrade with 4300k.. so will the 55w kit make them 3800k? i'm trying to achieve the most output possible.. thanks again :thumbs: |
Originally Posted by BenC5
(Post 1571643823)
Is this one of your projects for your engineering degree George? I would think by now you would have already passed the class.
-Alex |
I originally had the 6000K bulbs and as JMc had tested out the 5000K bulbs as they were indeed brighter/put more light on the road, I bought 5000K's and have been happy with them.
If the new cutoff AND 55W is even better, then I'm in. |
(Post 1571643823)
If I have 5000K bulbs, will I need to use new bulbs? If I can keep the 5000K bulbs I have, the new 55W ballast will then drop the output to around 4500K AND be a bit brighter? To summarize, I'll get; 1. New cutoff shields with instructions on how to change them 2. New ballasts which will increase my light output to 55W AND lower the Kelvin to around 4500K
Originally Posted by AlexSmith
(Post 1571644427)
-Alex The 500k drop in the 55w kits applies mostly to the bluer lights. 4300K will not be affected at all. 6000 will appear more like 5500k and 8000 will appear like 7500 K. it's also important to remember that HID bulbs will color shift towards the blue over a period of about 10-100 hours of use with the most dramatic change in the first few hours. the 55w will eventually shift back to their "noted" color. |
1. Csdunaway 2. Canyon Lake Corvette 3. QKSLVR Z 4. Ben C5 |
Ok, thanks for the explanation.
I'm in for the 4300K setup. Please let me know when/how to pay. |
GP update:
1. Csdunaway 2. Canyon Lake Corvette 3. QKSLVR Z 4. Ben C5[/QUOTE] 5. EG99hardtop (Hi-Low 55w HID) 6. 7. 8. 9. 10. |
great post George, cant wait to get em!
Come on guys, we need FIVE more to sign up for this great and awesome deal!
I almost can't imagine that my light cannons will be even better however, the new cutoff coupled with the 55W output, it will be WOWZA!
The name will need to also be updated to the "Light Howitzers" |
