Differences between 01,02,03 Z06
Looking for Z06 01 to 03, what are the differences in hp etc, I know there was horsepower change between one of these years to 405, would like some input as to which year to lean towards, hope I am posting this question in the right spot.
I think the fuel delivery was different after `02. They also had some suspension changes from `03 on.
2001 heads are different than 2002. HP increased from 385 to 405 from 01 to 02 as well.
Heads are the same. 2001 had less lift on cam no pup cats and intake hole was smaller.
Originally Posted by Roger420
(Post 1571652484)
Stolen from J-Rod @ LS1tech differences between 2001 & 2002 & up: 1. The LS6 engine standard in the Z06 increased from 385 to 405 horsepower. Torque increased from 385 to 400 lb-ft. 2. Front fender badges for Z06 models included the 405 HP designation. 3. LS6 exhaust back pressure was reduced by 16% 4. Cam shaft was redesigned resulting in increased lift and a 5% increase in air flow 5. Valve spring material composition was changed to increase seat load by 14%. 6. LS6 intake and exhaust valves were a new, lighter design. 7. The valve train weight was reduced by 0.81 pounds, which improved valve seating at high rpm. 8.Airflow over the LS6 MAF sensor was increased by removing grid work 9. MAF software was re calibrated 10. LS6 air cleaner housing had a larger intake 11. Wheels looked the same BUT they were cast spun instead of forged for a weight savings of 1.3 pounds per car 12. rear shock valving was changed 13. Improved clutch 14. Thicker front anti-sway bar 15. New front brake pads 16. HUD was standard (HUD was not avaliable in 2001 cars) 17. 2004 introduced a new fuel system which carries over into the new C6. The technical details on 2001 vs 2002 can be found here. http://www.idavette.net/hib/02ls6/index.htm |
I was in the market to purchase a Z over the summer. I drove all 4 years. I can tell you, seat of the pants on all four years is :eek::D.
(Post 1571652484)
Here is a link that should answer all your questions http://www.corvetteactioncenter.com/...z06/index.html
Thanks for the input guys it is appreciated! Anyone else care to add to this jump on in, I'm thinking that an 02 or 03 is the way to go from what I am seeing higher horsepower, not much if any price difference.
Originally Posted by Northern Performance
(Post 1571659449)
I figured last year of the C5, all the bugs that could be worked out were worked out by the last year. Don't regret it. |
This is from the sticky at the top of the C5/Z06 forum. It takes some reading, but it's all there...
http://forums.corvetteforum.com/c5-z...tions-faq.html |
