Budget/C6Z oriented suspension question for C5...
So I'm planning on upgrading to C6Z shocks and springs and T1 sway bars on my C5 coupe...
The way I understand it... C6 shocks and front spring will work on a c5 and c6 sway bars will work on C5. C6 rear spring has different mounting hardware. So I can't use the rear Z06 springs on my C5. What are you guys using for the rear springs to work with this setup then? Thanks for the help! |
Not a single person?
You don't have coil overs, the spring is separate from the damper on the rear. The c6z shocks should bolt on, but I don't know what you'll do for a rear spring to match the front spring.
whoops just realized I worded it wrong, thats what I get for posting at 4am.
I edited it to have it worded right. |
and still no one?
springs for the rear? |
I am not very knowledgeable as most on this forum, but read a lot.
Why are you wanting to put C-6 parts on your C-5? If you want to 'upgrade' and are on a budget factory C-5 Z06 parts are a better choice. Just MHO. |
I don't know the answer to your question. Might want to try asking people who have done it what they did.
I know VBP makes springs so they might be a source for the rear spring. |
I think Hyperco makes a spring too. Might want to figure out what the rear spring rate is on the C6Z and see if VB&P or Hyperco makes a corresponding spring.
Originally Posted by mgarfias
(Post 1571764179)
Originally Posted by Independent1
(Post 1571763226)
I know VBP makes springs so they might be a source for the rear spring. Thanks!! |
