A4 Tranny fluid
Hi All,
I would like to change my tranny fluid and would like recommendations, please. It is a stock A4(70K miles). Should I also change the diffy fluid at same time too? Thanks Steve |
unfortunatly you can't "change" your trani fluid yourself - to get all the old fluid out the trani needs to be flushed by a machine either at a dealer or trani shop.That being said, 70K on the old fluid is enough and you should select any quality name brand fluid. I use Royal Purple but any synthetic name brand will work just as well. You might want to consider changing the trani filter at the same time.
If the car is up in the air changing out the rear end fluid is no big deal. Again , I'm useing Royal Purple but you can do a search on either fluid to see what other members recommend.:cheers: |
A4 transmission fluid
I have been using Dexron VI . It is supposed to be a longer lasting fluid than Dexron III and is compatible with vehicles using Dexron III . according to what I have read.
HavolineŽ Automatic Transmission Fluid DEXRONŽ-VI Havoline Automatic Transmission Fluid DEXRONŽ-VI delivers value through: Warranty coverage as an officially approved General Motors fluid Improved durability of viscosity and frictional properties to ensure smooth operation in General Motors transmissions Extended drain intervals of at least 100,000 miles under normal operating conditions Back serviceability to cover all earlier DEXRON recommendations Mobil Dexron-VI ATF provides warranty protection for 2006 and newer GM vehicles. It is also for improved performance in 2005 and earlier GM vehicles, wherever DEXRON is specified When compared with earlier automatic transmission fluids, DEXRON-VI offers these improvements and benefits: From GM - enhanced performance of both new and older transmissions - longer ATF life (160,000 km/100,000 miles normal, or 80,000 km/50,000 miles severe). It is important to refer to the owner manual because certain vehicles recommend a normal service drain interval of 150,000 miles (240,000 km). - consistent shift quality throughout the life of the transmission - extended transmission life. http://www.sandyblogs.com/techlink/2...dexron-vi.html |
Originally Posted by vettezeke
(Post 1571815871)
Originally Posted by Blackjetvette97
(Post 1571813126)
Hi All,
Hi all,
Thanks for the replies, guys. I would like to know brand names and specific names of the fluid types(that will be on the bottles) so when I go to buy it, I won't screw up. Also, where can I get the required filter and other stuff needed to completely change out the fluid/filter(seals, if any)? Gonna have a tranny shop do the work. Thanks Steve |
Dexron III or VI will work. III is good for 50k miles and VI is good for !00k miles.
Hi all,
Thanks for replies. What was the stock fluid that was used in the '97 C5's? Mobil 1, Castrol, Havoline? Steve |
(Post 1571938390)
As stated earlier by vettezeke, Dexron VI is an improved fluid, and is my recommendation also. :thumbs: |
Originally Posted by old stingray
(Post 1571933640)
Originally Posted by 99 vett babycar
(Post 1571815729)
(Post 1571815729)
(Post 1571916322)
Hi all,
