LS1 / LS6 engine swap - Clutch, Flywheel, things to do
I've got a '98 Z51 C5 Coupe with a broken LS1 (106k miles). What we think happened is that the oil pump shaft broke and the engine saw 0 oil pressure and spun a rod bearing. The car is a weekend car and sees road course work and autocross. I've got an LS6 I will be swapping into it. I want maximum reliability and then anything modifications which will support track work. I have a few questions related to the engine swap:
1) What clutch/flywheel should I use? LS7 flywheel/clutch? Will this combo even work? LS6 flywheel/clutch? Spec3? I'm reluctant to do the Spec3 because I've read that some people have to get an adjustable master clutch cylinder to make the pedal engagement point work with that clutch. 2) I plan on replacing the throwout bearing and clutch slave cylinder and add a remote bleeder for the clutch while doing the swap. Is there anything else that should be done? 3) Should I worry about the torque tube and the rubber bushings on it? I think replacing the front bushing (nearest the engine) will be easy, what about the rear one in the transaxle? 4) Is there anything I should do the LS6 motor while it's out to maximize reliability? I am more than happy with the stock performance of the LS6. Your comments and opinions are appreciated. Thanks. han |
Originally Posted by sffish
(Post 1571824622)
The spec is the only "normal" unit avail that has an available (optional) alum pressure plate. Combined with an alum flywheel, it's about ~20 lbs lighter than an LS6, and even more so than the LS7. To go any lighter you have to get into small dia/multi plate set-ups. Whichever clutch you use, check the balance on it at a machine/engine shop, even if it's touted as being "balanced". |
