rear end noise- C6
I have a 2005 coupe with a six speed manual transmission. The car has 60,000 miles on it and I have a distinct rear end noise that tends to oscilate in intensity as the gears "load" and unload". This is most noticeable at highway speeds.
I actually had this same (or similar) problem right after I purcahsed the car. They replaced the rear end at 8,000 miles. Now It seems to be doing it again. This time no warranty coverage. Does anyone have any experience with this problem? Is this unique to early model C6's? Any help would be appreciated. |
The 2 problems I know of from searches are 1. loose axle nuts and 2. differential fluid upgrade.
I also have the clunking in my 07 M6. I need to check the axle nuts. I want to replace the differential fluid myself. Here is the TSB for it. http://www.corvetteactioncenter.com/...Noise+on+Turns |
Originally Posted by HaroldDE
(Post 1571839205)
Welcome to the Club
My 05 has 19K. I noticed the same sounds you describe. I changed the Diff fluid and used the Royal Purple. It already has the additive for the Posi. To be sure I added 4 Oz. of additive as well. No change in the Noise, I just learned to live with it. Seems most pronounced on the Highway in 6th gear around 70 MPH.
