inspection cover
i have a zz3 350 bolted to my original 64 muncie...problem is the 64 inspection cover will no longer fit...is there a cover that will bolt on to the newer engines with a one piece rear seal or will i have to modify the 64 piece thanks john b
did you reuse your original bell housing?
yes , bellhousing and transmission are originals
