how to change brake booster (92-95) with pics
14 Attachment(s)
ok, im going to show you how i did this, as i see its a common problem with these cars. im not sure if all years are the same, but im pretty sure the 92-95 are. my brake pedal was hard and hissed, so i knew it was the booster.
now, let me start by saying that im only 18 years old, have only worked on cars for a few years, have only had the vette less then 2 months, and i dont claim to be correct about this. i may have done things different from how others do, but this worked for me. ok, so lets get started. i started by removing the 2 screws (7mm) that hold the ecm down, then i moved it off to the side. Attachment 48157632 next i removed the bracket for the ecm. it was one bolt where my finger is (either 10mm or 12mm), and then it slides off its peg Attachment 48157633 next, i disconnected the cruise control cable. the clip on the end, u just stick a flathead under the tab, then push up and to the side. you should be able to figure it out. then you slide the cable off its holder, which you can see on the left of the pic Attachment 48157634 heres a pic of the clip so you can see what i mean Attachment 48157635 next, i removed the 2 bolts that attatch the master cylinder to the booster. you can see me pointing at the one, obviously the other one is on the other side Attachment 48157636 here you can see where i slide the master cylinder off the booster Attachment 48157637 next i disconnected the vacum hose that goes to the booster. it just pulls off, may be a little tight Attachment 48157638 now the next part is optional. some say you can do it without removing the seat, but i think it would be pretty damn hard to get to the boosters mounting bolts without getting in there. so i opted to remove the seat. heres just a pic of that. notice all the spare money i found! Attachment 48157639 next, i removed the panel under the drivers side dash. this also may not be neccesary but it made the job soooo much easier, so i recomend doing it. its only a few screws, sorry for the bad pic Attachment 48157640 next, disconnect the booster rod from the brake pedal. the clip is just a larger version of that little clip we took off the cruise control cable. once thats off, the rod can be slid off the side http://i570.photobucket.com/albums/s...r/DSCN0190.jpg next, you must remove the 2 mounting nuts for the booster. now this is rather difficult, and will certainly test your patience. you have to sort of lay upside down, as pictured, and get to the 2 bolts. i used a long socket with a 3 inch extension. its a 13mm. in the pic you can see the one nut on the right, and part of the left one. Attachment 48157641 heres how i layed in there Attachment 48157642 now heres where i ran into trouble. some claim you can remove the booster without removing the master cylinder, others say you cant. in my case, i couldnt. so i had to remove the cylinder. im sorry, i forgot to take pics of this but its pretty easy to remove. so heres after the cylinder and booster are removed. Attachment 48157643 and heres the cylinder taken apart. the resevoir was FILLED with chunks of crap, so i cleaned the whole thing out till it was spotless Attachment 48157644 and heres the new booster (left) next to the old one Attachment 48157645 now, i appologize as i didnt take any pics as i put it back together, i was on a tight time schedule trying to get it back together before the sun went down. but basically, you put the new booster in. i had someone hold it there while i reconnected the brake pedal. once that was in, i put the 2 mounting nuts on. (suprisingly it was easier for me to get them back on then to get them off). after the booster was on, i put the master cylinder on. then i put everything back together (basically the reversal of removal). now its all back together, and tomorrow i need to get new fluid so i can bleed the whole system out, and lets hope it works!!!! hope this has been a help to some people |
o, also i disconnected the battery, as once you disconnect the brake pedal, the brake lights will stay on
Excellent write up boss, i love it when people post up pics. (nice to see someone in my age bracket :lol:) Im gonna save this thread for later when i do this project.
Nice! These how-to's are great with pictures. Thanks for your efforts.
glad people appreciate it because it took alot of time to take/upload the pics, and do the whole right up. today i refilled the system with fluid and bled it all out, and the brakes work great now. no more hard pedal and no more hissing.
great write up keep it up next time you replace something
ya i plan on doing this everytime i fix something. the car doesent really need too much, but im constantly changing things on it. next on the list is plugs and wires. not sure if people really need a write up for that, but i figure enough people do them that maybe itll help some people out
you are a cool kid
Great write up. I couldnt really tell but it looks like your Vette has headers. If so I learned something a while back from a Guldstrand develpoment article while working on the ZR-1/tire program.
They had a 383 making some HP, with long tubes and the boosters were cracking from the heat at #7 header pipe. So, they put a heat reflection cloth, to keep the heat away from the booster which is susceptible from the heat. As you may not know, the ZR-1 have metal boosters. So, to keep the booster from cracking again from the heat of the header, wrap the booster with something to keep the heat off of the booster by #7 cyclinder. Steve Hopefully this pick kinda helps. http://i33.photobucket.com/albums/d8...h/DSCN1723.jpg |
thanks! thats actually a good idea. my car has shorty headers but i plan on going with long tubes within a year. i might go ahead and put some kind of heat shield near mine. i got a lifetime warranty on it but id rather not replace it again
coated headers are fine
Originally Posted by SmokinRide
(Post 1571911258)
The shielding I used dropped it 250 degrees at idle. Imagine what the heat is driving down the road. |
Excellent write up. :thumbs::thumbs: Good job. :thumbs::cheers::flag:
nice work,
:cheers: |
Nicely done - bravo!
Great write up and photo's. Thanks for taking the photo's, it will really help when I change out mine.
if you end up having to take the master cylinder off, which im almost positive you will, make sure you bleed the brakes out GOOD. mine got alooot of air in them when i did this
cool write up, thanks for the info.
Great write up. I love write ups with pictures.
Nice Thread!! It helps me a lot doing mine booster.
Greetz from The Netherlands (Europe) Wouter |
