Tire Pressure monitoring system for a trailer?
Has anyone put one in their trailer?
I really like the Hella system that I put in wife's Volvo. It does pressure and temperature. Might be nice if I had a brake problem too. I've seen some that have a repeater for trailer use. It mounts on the back of the truck or RV. thanks in advance |
That would be nice
I blew a tire on a trailer and didn't notice it till a helpful driver yelled over to me and saved my ride. |
Drive with the windows down, you'll hear the "pop".
I think I will put this one on
http://www.tirerack.com/accessories/detail.jsp?ID=160 |
Originally Posted by johninar
(Post 1571992395)
Originally Posted by Jason
(Post 1571990815)
Smoke in the side mirrors happens too. |
Originally Posted by AU N EGL
(Post 1571992565)
And smell the burning rubber, hearing a loud flap flap flap
And get TWO spares trailer tires.
and a little ramp to drive the good wheel up onto to change the blown out tire |
Oh yeah, 2 spares. You'll get as good changing trailer tires as you will car tires.
I've also seen CC video configurations where he used 4 video cameras mounted on the back, the sides and even under the trailer so he could actually view the tires! Great stuff!
(Post 1571990104)
I've been using a tire pressure monitoring system on my trailers for several years now, and once you have it you won't want to tow without it. It gives you a read-out as well as warnings if it goes below 10% of your starting air pressures. It makes towing more relaxed as you don't have the guessing game going on.
I found the Pressure Pro system to work really well and after probably 5 years of use it is still working like the first day. They also have a repeater for long trailers so you can still get a strong signal. I'm sure they have a website, but here is the phone number: 816 887-3505 they are out of Harrisonville, MO. :cheers: |
I lost a wheel off my trailer.... I wonder if that would have set off the low pressure alarm ??
Originally Posted by Donny Brass
(Post 1572001082)
I was at a camping world earlier this summer and saw they had a couple different systems for motorhomes and trailers.
