Recommendations for a floor jack
Gents,
What are some good floor jacks? I do have a local Harbor Freight, but I bet most of the stuff is made in China (low quality). The last time I had a floor jack was in the 70's/80's when I worked on my 71 El Camino. I don't want to spend a lot of $$$ but want a decent one. Does Sears Craftsman make a decent one? |
I have a Torin aluminum jack that I like. It's nice and lite, and <$100. Costco sells them as well as Northern Tool & Equipment. I think it's the same as the Craftsman, but Sears charges a few bucks more.
Thanks Tom. Went to the Costco site, and I'm assuming its this one:
http://content.costco.com/Images/Con...uct/159901.jpg http://www.costco.com/Browse/Product...t21277&topnav= Also checked out Sears, and all the floor jacks mentioned, a lot of people were not every happy with, including some of the more expensive ones. Went to Harbor Freight on line and did not see any prices. |
I got the Arcan XL35. It's a tank, very durable and gets the car up quick. You can see pictures of it in this older thread:
http://forums.corvetteforum.com/c4-g...le-jack-3.html |
Originally Posted by Wathen1955
(Post 1572010588)
http://content.costco.com/Images/Con...uct/159901.jpg http://www.costco.com/Browse/Product...t21277&topnav= Also checked out Sears, and all the floor jacks mentioned, a lot of people were not every happy with, including some of the more expensive ones. Went to Harbor Freight on line and did not see any prices. I've had mine for 4 years now and while I don't use it a lot, it has developed a nasty hydraulic oil leak at the piston. It won't lose height if I raise the car and leave it in the up position, but I now check fluid level before each use and top it off. But's a PITA to clean the floor or step in the fluid :willy: |
NAPA sells a low profile jack. It is more expensive than all other mentioned above but it is great to work on C4s.
:thumbs: |
I have a great craftsman jack that's just a liitle too tall to get under the car. Ugh. Be careful.
Harbor Freight jacks are a-OK. I have 2. They have a low-profile, high-lift one for $80. It's steel, so it's heavy, but they also have a comparable Al one for $150. Just depends what you care about.
I also have the XL-35 I purchased from the local Costco....Great Jack!
Harbor Freight is running a sale, take a look in magazines. They have a full page ad. Low profile jack for $70.
I bought a Craftsman jack for $200 and it isn't what you would expect. It works pretty damn good, but it also leaks like a sieve. Also the saddle isn't removable, so you can't put a "jack-a-vette" on it. |
This was a question I had a few weeks ago until I bought a spectacular jack. I bought an Arcan Quick Lift Service Jack. It fits under my lowered C4 at 3.5 inches and raises it to above 21 inches. It raises quick, is relatively cheap at $150, and gets an almost perfect 4.9 out of 5. I also bought 4 Torin jack stands to support the Vette off the ground. Check it out:
http://www.northerntool.com/webapp/w...5429_200345429 |
Originally Posted by VetteTheWorld
(Post 1572011874)
(Post 1572010588)
Originally Posted by StealthLT4
(Post 1572011067)
(Post 1572009911)
Gents,
I do have a local Harbor Freight, but I bet most of the stuff is made in China (low quality). |
I have a craftsman jack that works fine. It is a little high for the vette so I drive onto a couple of boards first.
I bought the Harbor Freight aluminum low profile one. The magazines have an ad for $59. I tried it and it works good. For that price, I bought a second one. I need the low profile on my C5.
For the C4 I have a Craftsman steel 3 ton floor jack. Not a low profile one. They put them on sale once in a while for about the same price. I generally like the Craftsman better, but the aluminum ones do work OK so far. |
I don't think that I would trust a Harbor Freight floor jack. A lot of the stuff from them is junk. I have 2 Craftsmen floor jacks. They are very rugged and reliable.
The harbor freight jack is now $59.99
Originally Posted by Mr Mojo
(Post 1572016937)
