under drive pulley
what is involved to install an under drive pulley and what kind of HP gains can I expect on 02 a4 fast92/92 cam heads lth high flow cats stingers and tune thanks for any info:cheers:
Here is ATI's instructions but they dont tell you all the bs you have to get by or remove like the whole steering rack.
http://www.andersonperformance.net/C...er_Install.pdf |
I would personally NEVER install an underdrive pulley unless I was already in there doing a cam change. There just isn't enough real dyno evidence of rwhp gains to warrant the major PITA :rofl: of removing the steering rack and pulling the balance (and of course installing new seals etc.)
I have one laying around in my shop that I could put on my wife's car, but wouldn't dream of doing it unless we install a cam :smash: There are a lot more low $$ mods you can do and get proven gains (not gains the vendor claims) |
Originally Posted by Blow Torch
(Post 1572231695)
I have one laying around in my shop that I could put on my wife's car, but wouldn't dream of doing it unless we install a cam :smash: There are a lot more low $$ mods you can do and get proven gains (not gains the vendor claims) Engine driven accessories like the alternator, water pump, and power steering pump have a fairly linear curve when it comes to sucking power from the engine. Changing drive ratio is much like shifting to a lower gear allowing faster acceleration. One of the biggest advantages that most people over look is the inertia factor. By using an underdrive pulley, the alternator isn’t spun up as high as with the stock pulley ratio. The alternator is the largest inertia load of all accessories. It plays a major factor on how rapid the engine can rev, much like the inertia of a light versus heavy flywheel. In simple terms it plays a big factor on throttle response. If performance is your game or desire, and you don’t expect to drive your car when it is -40 deg’s outside, then going to an underdrive balancer might be a reasonable choice to gain performance. :cheers: |
I stick to my statement "Show me the money":lol:
I have seen three attempts at dyno "test" on underdrive pulleys and the MOST I have ever seen was 6hp (one showed 1 hp) That is not enough for me to bother with :toetap: |
What about ECT's. C6's run 198-205 degrees normally. With less cooling volume what would happen to the water temps?
Well, I can't give any dyno comparo, since I also wouldn't think of messing with a pulley swap unless a nice cam went in also. But, I do have experience on the effects of a 25% pulley on the accessories.
- Water temp went up from 183 to 185 when freeway cruising steady-state in 6th gear in 100-degree weather in Texas. No noticeable change in stop-go. - AC showed no detectable change in the hot Dallas summer. - Charging circuit unaffected, but I rarely play the radio. - Steering effort displays a very slight tug when starting off from a rest and turning the wheel sharp - like backing out the drive and heading out down the street. Perfectly acceptable. - My ASP pulley has absolutely zero wobble, much better than the stock unit. I feel certain all my accessories, belts, and the infamous idler pulleys will last longer - just seems logical. One last thing - I did a lot of small mods to my C4 Vette, like exhaust, intake, chip, etc. The only mod I could definitely feel was the underdrive pulley. DG |
I had one on my car years ago and I believe it was worth 5 RWHP.
Best of luck to you with your future mod decisions. :cheers: |
5-9 rwhp on a dyno.
On an F-body it's a good mod even if you're not changing the cam.... on the Corvette it's much more work pulling the steering rack. Save that mod for when the cam is being changed. |
or just do what I am in the middle of doing. wait for your stock harmonic balancer to go to sh*$. Then since you gotta replace that anyway.. might as well upgrade
Originally Posted by marinehacker202
(Post 1572370001)
should just go ahead and stick in a cam too :smash: :D |
Too much work for less than 10 HP
Originally Posted by vetterdstr
(Post 1572366183)
