How to find the vacuum leaks, and test system
For what it is worth, or anybody ever had this thought....
I went out to Harbor Freight and purchased for ~$70 a vacuum pump, It's original intent was for drawing down the lines on the A/C system. I measured the vacuum level and it holds steady at 17"... cool... So, I disconnected the engine from the vacuum system and replaced it with a 20' hose (Home Depot) that hooked up to my pump which I placed outside not to hear it run.... Now, in much needed silence I am able to listen for leaks and the such, operate all systems, and work all controls for testing.... It works great!:thumbs::thumbs::cheers: No engine noise, fumes or any other type of noise,,,, just a heads up...... found 2 leaks...:eek::eek: |
Just as easy to connect that 20' hose to a vacuum source on another car sitting outside.
pauldana: Good idea. I also have a vacuum pump I use for the A/C system. I'll keep this in mind next time I'm chasing a vacuum leak.
Originally Posted by Mike Ward
(Post 1572417686)
Thx... someone pm'd me for a pic and a few more details, so I thought I would just give it to everyone interested.
http://i593.photobucket.com/albums/t...1/IMG_0794.jpg DO NOT use the cheap clear hose, it just collapses under the vacuum, instead I went back and got the much thicker hose with thread in it, the one pictured and hooked up, no problems...... opens and closes lights, vents, A/c & heater stuff...... found out, when you have a leak for the heater controls the lights work poorly also... directly tied in. This does work very well, Again, just disconnect the vacuum line to the intake manifold and replace with pump line..... Should work for brakes as well!!:thumbs::cheers::lurk::D |
vac leaks
smoke is a good way to look for leaks ypu can use stick incense and doesnt smell bad of course no breeze also have used air preassure and some bubble leaks detector judt a small regulator to crank air down as to noy blow the lines apart
Originally Posted by 69small block
(Post 1572420069)
Also tried a big craftsmen shop vac... no go, not enough negative pressure. As far as the second car thing...I see lots of problems there... as i am sure most do..... this is so simple and works so good..... wish i would have thought of it years ago.. would have save me a lot of trouble. |
Originally Posted by pauldana
(Post 1572420313)
As far as the second car thing...I see lots of problems there... as i am sure most do......
(Post 1572422172)
Like what?
hey, I'm not saying it wont work, and if money is very tight I am sure it will get you by. but it is nice to have the right tool for the right job, I hate to BUBBA things.... To his, his own.... if the duel car thing works for you:thumbs::thumbs::thumbs::cheers::chee rs: I don't mean any offense, Just not like the way I like to do things... thats all. :lurk::cheers: |
(Post 1572417664)
I went out to Harbor Freight and purchased for ~$70 a vacuum pump, It's original intent was for drawing down the lines on the A/C system. I measured the vacuum level and it holds steady at 17"... cool... So, I disconnected the engine from the vacuum system and replaced it with a 20' hose (Home Depot) that hooked up to my pump which I placed outside not to hear it run.... Now, in much needed silence I am able to listen for leaks and the such, operate all systems, and work all controls for testing.... It works great!:thumbs::thumbs::cheers: No engine noise, fumes or any other type of noise,,,, just a heads up...... found 2 leaks...:eek::eek: You are the Man.:thumbs: Thanks for the info.:thumbs: I have a harbor freight just up the road and a few known leaks in both of my cars. This will be a huge help for me.:cheers: |
(Post 1572422349)
If a bad leak it will effect the car giving vacuum........
I hate to BUBBA things.... I don't mean any offense, It takes 10 minutes to properly troubleshoot. 10 minutes of running a car at idle is a bad idea compared to spending 70 bucks on a pump that you'll use once? There's nothing Bubba about using a second car. You must have a wine and beer making place in town. They rent vacuum pumps normally used for filtering wine. 5 bucks a day usually. If you don't mean offence, then think twice about what you post. |
(Post 1572422532)
Why would it affect the other car if it didn't affect the Corvette?
It takes 10 minutes to properly troubleshoot. 10 minutes of running a car at idle is a bad idea compared to spending 70 bucks on a pump that you'll use once? There's nothing Bubba about using a second car. You must have a wine and beer making place in town. They rent vacuum pumps normally used for filtering wine. 5 bucks a day usually. If you don't mean offence, then think twice about what you post. But for those of us like me, that like to wast our money on tools, this works great... :-) |
(Post 1572417664)
(Post 1572420313)
(Post 1572422172)
Like what?
Merry Christmas to everyone :cheers:. |
Originally Posted by ...Roger...
(Post 1572425219)
Like that little SOB down the street from me, he would be in that outside car and gone especially if it was a Vette. :rofl::rofl::rofl:I'd like to #$%@^ that little &%^*$.
Merry Christmas to everyone :cheers:. funny...:-)....... yea, mine only pulled down to 15-17"... it was the cheaper pump of the two offered at Harbor Freight I will also be using this to help with the recharging of the A/C system on the Vett and my truck....O... another use for the tool.....cool..p:-) Merry Christmas everyone!!!!!! From Lancaster Ca. USA |
The car-to-car thing is an old mechanic's trick. Good vacuum sources were BB Pontiacs and Oldseys, as they made tons of vacuum. I forgot this tip until this thread!
