Z06 rear Brake Duct Template * FREE *
I've had alot of questions about the brake duct install again, so I'll post my original template here for anyone who needs it. I had an extensive write up here on the forum in 2003, but all that is left is a cliff note version. If the template will not download, PM me your email and I will send them to you.
Caution: This is your car and you will make a mess of it if you don't check and re-check the fitment before you cut a hole in it. I am only giving you my experiences with this project in hopes you will have the same great results I had without any guidance. This is an exact template, so do not let your printer "scale to fit." go to FILE, PRINT and when the print dialog box pops up, choose NONE in the PAGE SCALING drop-down. Also make sure it does not auto rotate either. the image will extend beyond the printable edge and that's how it was designed to be. By reducing the image it will affect the fit. http://im1.shutterfly.com/media/47a4...D550/ry%3D400/ Instructions for template: First, check that the template you printed is correct by measuring from the center of the match marks (center to center). It should be just a hair longer than 6 3/4". The distance between the furthest bolt holes will be 13 1/4". Line up the index match mark keys and tape both pages together(hold it up to the light). Cut out the center section, outer edge, bolt holes and then overlay it onto the actual plastic duct. If it fits, trace it over to poster board or the cardboard from the box they were shipped in. This is now your actual template. Check the fit again. Use the same template for both sides so that the position is symmetrical and consistent. Trace the template onto the taped up body panel. My ducts did not come with the nuts to install them with: They are 8mm (M5) and you can find the rubber-backed washers and nuts at Home Depot. You'll want the nuts with the plastic locking ring because you don't want these coming loose or to need to overtighten them. **The distance from the outer plastic duct edge to the body seam-line (door/rocker edge and rocker top edge)is between 1/2"-5/8" as measured on a factory Z06. *Just to be perfectly clear here. Put the plastic duct into the template and trace the outer edge of the plastic duct onto the template (see second picture). This is the penciled line you will use to get the 5/8" distance to the panel's edge. NOT THE TEMPLATE EDGE! capiche! The template is bigger than the duct itself and should line up correctly on the edge. However, this will correct for any variations in the manufacture of the ducts. Note the second picture, my template was not all the way to the top edge. Once the hole is cut you may have to clean up the edges to get a snug fit. Test fit the studs on the template before you drill them into the car. Just a couple of notes on cutting the holes: If you use a cutting disk, you will have dust everywhere and shorten your life by breathing in the dust. A RotoZip is impossile to control and you may ruin your rocker panel. I would recommend a jigsaw with a new "fine tooth" blade of 14 teeth/inch. Tape the car body with blue painters tape to keep the fiberglass from chipping and to protect the paint from the jigsaw shoe plate. Start by drilling a starter hole in the cut out area near the line so you can drop the blade in without damaging the body panel. If you are nervous, drill the hole in the center and work your way to the line with the jigsaw. Along the bottom edge you will bump into a steel frame rail a few inches from the very front (see 4th picture). just raise the blade until you cross over it. Go slow and let the blade cut without forcing it. Finally, finish up by using 320ish grit sandpaper, smooth all cut edges to stop the paint from peeling Z06_brakeductTemplate1of2.pdf Z06_brakeductTemplate2of_2.pdf * Alternate template link Feel free to donate to my Hawaii vacation fund for this valuable service. It's gotta at least be worth beer money. current balance....$0 :toetap: This is how it looks taped together http://im1.shutterfly.com/media/47b9...D550/ry%3D400/ Template taped in place http://im1.shutterfly.com/media/47b9...D550/ry%3D400/ Traced onto car http://im1.shutterfly.com/media/47b9...D550/ry%3D400/ finished with the cutting http://im1.shutterfly.com/media/47b4...D550/ry%3D400/ http://im1.shutterfly.com/media/47b4...D550/ry%3D400/ http://im1.shutterfly.com/media/47b9...D550/ry%3D400/ Success! http://im1.shutterfly.com/media/47b4...D550/ry%3D400/ |
Nice DIY. I put those on my coupe.
I think they are mandatory on FRCs... but having the template and some visuals FREE :eek: is a great idea
Merry Christmas! :blueangel: |
Thanks for the write-up. Planning on installing these on my Pewter 99 Coupe.
Jason |
Thanks for posting that up. Nice of you to take the time to do this.
I installed a set on mine a year ago and they look great!! So for anyone who thinks about doing this, it is a great mod and pretty easy to do...just measure twice and cut once. Indy
Subscribing for use :thumbs:
Thanks,Matt |
What about the duct? What did you use to make the cut? Anyone have the Factory Z06 ducts and Race Mesh Grilles? Is it an OK match? Or does Race Mesh make a grill for these too?
Originally Posted by madmatt9471
(Post 1572506934)
Thanks,Matt |
Very nice of you to post for free...!! :cheers:
Mele Kalikimaka! |
Originally Posted by IRON MAIDEN
(Post 1572507153)
A word of warning on the duct. It needs to be inboard as far as possible to prevent rubbing by the wheel. Put the wheel on to make sure you have enough room for suspension travel. If you want to know the truth, these rear ducts do nothing to cool the brakes. They are too far away and don't do what they are supposed to do. Besides that, the rear brakes rarely get hot enough to worry about. If I had to do again, I'd probably leave the wheel well intact and seal the duct on the inside, less a hole for water to drain out. IMHO search out how racers plumb the ducts and you'll see why I say that. The duct is typically attached to the hub just millimeters from the center of the rotor. http://i703.photobucket.com/albums/w...DSC00933-1.jpg These GM ducts are miles away and just fill the wheel well with undirected air. The rotors get no benefit. But it does look cool. :cheers: |
Wow, nice work. IMO, it takes cajones the size of bowling balls to cut into your $50,000 car. Glad mine came with them from Chevy.
What do the grilles run? Maybe RaceMesh can make a screen for them so all my screens match. Iif function on these is a waste, I will just install the grilles and seal off the back of them so no water and crap collects in there.
Anyone see any problem with the back of these being capped off? Not sure if the wind not having anywhere to go will be an issue. Noise, whistling????? |
I just bought the screens and ducts and your post is timely and a great help. Many Thanks :thumbs:
I just ordered the rear brake duct kit from Ecklers 5 minutes ago, I'm sure if the kit doesn't come with the tempates I'll be using yours. That Ecklers price of $339 for the kit is a heck of a deal. Because I read your thread I decided to do it, :thumbs:
C5's still cost $50,000? Guess I got a deal on my 2001 with 14k on it for $25,000 then!:D
Originally Posted by flynbyu2
(Post 1572508426)
You can get it cheaper than that from that GM parts guy here. I think I paid well under $200 cause I bought used ducts but new grills. Still buying from GM is still cheaper than Ecklers!
http://forums.corvetteforum.com/c5-g...rts-house.html Z06 rear screens (scoops) – 159.76 (both scoops total) On our website, use part numbers 10322761 and 10322762 under Chevrolet make. Z06 rear brake ducts – 47.01 (both ducts total) On our website, use part numbers 10425976 and 10425977 under Chevrolet make.
Originally Posted by SNOTRKT
(Post 1572697287)
I'll remember that for my next C5 purchase, ordered the kit a week ago from Ecklers. Around here the dealership wanted close to $500 for all the parts so thats part to do with why I purchased it from Ecklers.
Originally Posted by nextime
(Post 1572771281)
http://forums.corvetteforum.com/c5-g...rts-house.html Z06 rear screens (scoops) – 159.76 (both scoops total) On our website, use part numbers 10322761 and 10322762 under Chevrolet make. Z06 rear brake ducts – 47.01 (both ducts total) On our website, use part numbers 10425976 and 10425977 under Chevrolet make. |
Did that mod for a friend! Turned out nice!
I want to install these on my Vette so badly, but I am horrified to try! I think I would throw Up as soon as I began cutting into my car! :bigears
