do '09 tire pressure sensors fit in '05 wheels?
Will the '09 sensors in my current wheels fit into the '05 wheels w/o any issue? It looks like it has some band system from some pictures I dug up, so if it's the same diameter, it would all just swap over?
Originally Posted by turbotuner20v
(Post 1572606896)
http://i68.photobucket.com/albums/i1...e/DSCF0144.jpg http://i68.photobucket.com/albums/i1...e/DSCF0145.jpg All OE wheels mount sensors in a similar manner, so the sensors out of your '09 wheels will fit in your '05 wheels. All sensors for C6 model years 2005 to 2009 are the same and will work in any of those year C6s (they are all GM Part# 25758220). I believe 2010 C6 sensors are a different part# and won't work in earlier C6 years. Bob :flag: |
Originally Posted by BEZ06
(Post 1572608251)
There is no "band system" in OE wheels. The sensors mount in OE wheels as you see in the pictures below, i.e. the valve stem sticks out of a hole in the wheel and has a retaining nut on the outside:
(Post 1572608251)
http://i68.photobucket.com/albums/i1...e/DSCF0144.jpg http://i68.photobucket.com/albums/i1...e/DSCF0145.jpg All OE wheels mount sensors in a similar manner, so the sensors out of your '09 wheels will fit in your '05 wheels. All sensors for C6 model years 2005 to 2009 are the same and will work in any of those year C6s (they are all GM Part# 25758220). I believe 2010 C6 sensors are a different part# and won't work in earlier C6 years. Bob :flag: was ordered. Then went in. Long story,,,,, I kept having problems with the right rear wheel the one with the new clip. Sensors coming loose. By 6 appointments later I ended up ruining 3 sensors. Then went to Discount tire. Wish I had a picture. The boobs were banding the sensor to the rim. By clamping to the rim. With no cradle or clip to hold the sensor.:mad:.. I mailed them a letter telling them replace my 3 sensors to the wheels I was taking them out of. My spare stock set. They replaced them but they operate on a differrent freq. Lucky I have a good TPMS tool that reset's any TPMS sensor. |
Bob I KNEW you would know this answer! Turbotuner wants to buy my old wheels and asked me...I said throw up a post, or PM Bezo6!
You are THE SOURCE when it comes to things tire sensors.:thumbs: |
Originally Posted by Rock'n Blue 08
(Post 1572608406)
I bought some HRE wheel's off the forum. They have the bands which work well when put in right. The bands came with the wheels. One little clip was missing from one of the bands. I waited till the piece
Originally Posted by Joe_G
(Post 1572608430)
You are THE SOURCE when it comes to things tire sensors.:thumbs: BTW Turbotuner - if you're taking the sensors out of your '09 wheels to put into the '05 wheels, if the tire shop keeps track of which sensor came off which corner of the car and puts them into the '05 wheels so the sensors go back on to the same corner they were originally on, then you won't have to do any relearn procedure to program the sensors to their new locations. If they get mixed up they'll still work, but if the DIC says "Left Front 23 psi" it may be talking about the Right Rear (or where ever the one that was originally in the LF ended up). Rock'n Blue 08, you say: They replaced them but they operate on a differrent freq. Lucky I have a good TPMS tool that reset's any TPMS sensor. Some sensors are triggered by a magnet (e.g. C5 and a very few real early C6 sensors, and some used on some Chrysler/Jeep vehicles), but to my knowledge ALL sensors that are triggered by a radio frequency require a 125 kHz freqency to trigger them - I've never heard of a tool that transmits a triggering signal on any other frequency. The sensors themselves transmit their data to the radio receiver in the TPMS computer in the car on a totally different frequency. Our C6 sensors on ALL U.S./Canada cars transmit to the TPMS computer in the car on 315 mHz (Euro spec C6s use a sensor that transmits on 434 mHz). So.....for a C6 built to North American specs, only the Schrader sensor that is GM Part# 25758220, the same sensor directly from Schrader with a part# 20076, or possibly another sensor made by Orange Electronic will work. All will be triggered by the standard 125 kHz transmitted by all tools. I'm not sure, but I think the 2010 C6 uses a different sensor than the earlier C6 model years. The TPMS in the car is actually part of the RCDLR module, and I believe the TPMS computer in the 2010 C6 is similar to that used in some other GM vehicles in the past. I think the 2010 uses the same tire pressure sensor as the Malibu and Escalade (and maybe some other vehicles) and that you don't need a tool at all to trigger them - you can trigger them by changing pressure in the tire by +/- 8 to 10 psi. I believe they will also respond to the 125 kHz triggering frequency from a tool, but a tool is not necessary (at least I think what's in the 2010 C6). Bob :flag: |
