SPRINT BOOSTER- Improve Trottle Response
http://ep.yimg.com/ca/I/yhst-3878695338535_2091_3633484
Help Eliminate Trottle Response Lag You have probably noticed your C6 Corvette's throttle response is much less than instant. You know, you mash the pedal and the car does not react as quick as you would like. This is due to the late model Corvette utilizing an electronic throttle control system, also known as drive by wire. Things like pedal sensitivity, stability control and traction control systems all factor into the final throttle signal to the ECU (engine control unit). ECU communication with these various systems creates a noticeable lag or delay in throttle response when it's go time. Sprint Booster Power Converter is an aftermarket electronic module that plugs in between the accelerator pedal and the engine control unit (ECU) of your 2006-2010 C6 Corvette. Sprint Booster greatly improves acceleration and off the line performance by continuously measuring and converting the digital signal, providing the ECM with a new and altered signal. Sprint Booster improves response, increases pedal input sensitivity and delivers more impressive off the line performance you can really feel. http://ep.yimg.com/ca/I/yhst-3878695338535_2091_3723960 http://tkoperformance.com/sema.gif Sprint Booster has been awarded the coveted 2009 SEMA Show “Best New Performance Street Product,” for 2009. Chosen over 1228 other entries. Sprint Booster modules are available for automatic or manual transmission equipped 2006-2010 C6, C6 Z06 & Zr1 model Corvettes. This is the new 2nd generation Modules which includes an on off switch. $329 Free S&H Click here to purchase Online http://store.tkoperformance.com/sppoboimthre.html When ordering online a Ship charge will pop up However just write "Corvette Forum Member" in the Comments field for no Shipping Handling. We manually take care of it.:thumbs: OR Call in your order! 1800 778 9898 Thank you :cheers: Allow 1 week to ship out. |
Originally Posted by TKO Performance
(Post 1572894322)
Help Eliminate Trottle Response Lag You have probably noticed your C6 Corvette's throttle response is much less than instant. You know, you mash the pedal and the car does not react as quick as you would like. This is due to the late model Corvette utilizing an electronic throttle control system, also known as drive by wire. Things like pedal sensitivity, stability control and traction control systems all factor into the final throttle signal to the ECU (engine control unit). ECU communication with these various systems creates a noticeable lag or delay in throttle response when it's go time. Sprint Booster Power Converter is an aftermarket electronic module that plugs in between the accelerator pedal and the engine control unit (ECU) of your 2006-2010 C6 Corvette. Sprint Booster greatly improves acceleration and off the line performance by continuously measuring and converting the digital signal, providing the ECM with a new and altered signal. Sprint Booster improves response, increases pedal input sensitivity and delivers more impressive off the line performance you can really feel. http://ep.yimg.com/ca/I/yhst-3878695338535_2091_3723960 Sprint Booster modules are available for automatic or manual transmission equipped 2006-2010 C6, C6 Z06 & Zr1 model Corvettes. This is the new 2nd generation Modules which includes an on off switch. $329 Free S&H Click here to purchase Online http://store.tkoperformance.com/sppoboimthre.html When ordering online a Ship charge will pop up However just write "Corvette Forum Member" in the Comments field for no Shipping Handling. We manually take care of it.:thumbs: OR Call in your order! 1800 778 9898 Thank you :cheers: Allow 1 week to ship out. Seems like a neat idea but I'm just a little hesitant messing with my throttle control. Don't need any unintended acceleration like in the Toyota's just recalled. |
Originally Posted by GTJim
(Post 1572894528)
Interesting. Does this cause any problems with any of the other electronic systems the Corvette has ??? How hard is it to install ???
Yeah i had this on my M3, next to already sport button that M had. It made huge diference.
sprint booster
what about the 2005 z51 ?
thats pretty pricey!
Originally Posted by Cdn Z06 Mike
(Post 1572895613)
This won the 2009 SEMA product of the year I believe. It does not affect any other systems on your vehicle so no worries regarding the "Toyota" concerns lately. Plug it in and enjoy the instant response. Have seen this in use for close to 2 years (BMW) and no issues.
Yea its a pretty nifty little mod. I have heard nothing but good things about it too. Its a simple install. Most who try it (when demo'd at a shop) tell the salesman, leave it in I'll take it! :cheers:
Originally Posted by Dado5
(Post 1572895667)
Originally Posted by wolfdogs
(Post 1572898613)
Originally Posted by bobbya55
(Post 1572898539)
Thank you |
So it sends the throttle signal faster to the TB? Then tells the TB to open faster?
So...
I don't suppose it would make the throttle SNAP like on my 72 C3 with a carburator? Now that would be cool. :thumbs:
can you post install directions?
what is your return policy? |
I have a Predator for my car but have not installed a tune yet. Do I need this booster on top of the Predator?
:lurk:
I think this is a signal multiplier. So 1/4 throttle feels like 1/2 throttle ect. Interesting and like Wolfdogs said it is pricey
Originally Posted by check6x
(Post 1572900363)
My Z06 was tuned with LS2Edit, and the throttle response was a lot better than stock also. I think a PCM tune changes the throttle tip-in by adding fuel earlier/quicker when the throttle comes on. This unit doesn't do that - it sounds like it just simply changes the voltage sent by the APP (Accelerator Pedal Position) sensor to the throttle, which makes the throttle blade react quicker to the pedal. So....it doesn't do anything through the PCM. With all the talk about tunes voiding the warranty I'm not sure I want to tune my new car (at least not yet), so I'm thinking about this unit to get better throttle response. Bob :flag: |
Originally Posted by BEZ06
(Post 1572902349)
I had a Predator tune on my 2005 C6, and the increased throttle response was one of the things I liked the best about it - it was like my short-throw shifter in that I noticed them both every time I drove the car, even if it wasn't real spirited driving.
My throttle responce is VERY quick !
(Post 1572898613)
Originally Posted by knkali
(Post 1572902332)
Originally Posted by xlr8rvette
(Post 1572902986)
So you would be at WOT by say 1/2 peddle travel? You really don't "get" anything more, just loose throttle control and feel. How would this be different than wearing three pairs of socks and work boots and just jamming away at the throttle? :toetap: |
Originally Posted by EDinPA
(Post 1572903158)
If electricity travels at the speed of light, then how does this device get the pedal position to the ECU faster? |
(Post 1572895667)
Originally Posted by Boomer111
(Post 1572903818)
I did not use it much on my M3. For me it was to responsive for around town. I guess though that one could get used to it but I did not give it much of a try. It really did speed throttle response up a lot. Humm for me it is a tough call with the Tq of the LS3.
Originally Posted by brettbolt
(Post 1572903269)
:iagree:
If electricity travels at the speed of light, then how does this device get the pedal position to the ECU faster? Its a nifty lil mod. Sprint Booster was awarded the coveted “Best New Performance Street Product,” At SEMA for 2009. Chosen over 1228 other entries. Not to shabby... Ed |
