Auto Transmition 3rd gear not working
I have a 96 corvette with automatic transmission. I was on the high way and passing someone. Then the 3rd gear and overdrive gears did not catching. Now I only have 1st and 2nd gear. When it trys to go into 3rd, it just spins, like it is in neutral, it will not give me 3rd gear. I drove the car home in 2nd gear and it is stilling in my garage. No leads, has oil. What is the problem? What can I do?
Peter |
Originally Posted by vettebiker
(Post 1573026819)
Peter |
Did they have to rebuild the tranny, and if so what did it cost?
(Post 1573029966)
:lurk:
Same thing happened to me- lost 3rd & 4th and it required a rebuild.
Make sure you take it to a reputable transmission shop, which can be hard to find. My guy talked the talk, but it was slipping two years later. |
:sadangel: Sorry to see that for you so early in the spring. Good luck.
