Block 3/8 thread pipe plugs torque Spec's
Does anyone know if there is a torque specification for installing the 3/8 inch pipe thread plugs on both sides of the bottom of the engine block?
I plan to use pipe thread sealer and install the plugs snug, but was wondering how tight I can go in ft lbs. Thanks |
Check your post in the parts section.
Originally Posted by midyearvette
(Post 1573043122)
Fortunately we take better care with our Corvettes. Larry |
Thanks everyone for the input.
I did not think there would be a torque spec for pipe plugs. Ask and you shall receive. I never saw a plumber with a torque wrench. I guess we get a little too anal when we do our own work. I did not know I was in parts section when I 1st posted , didn't see the post and re posted in the general section. Another senior moment. |
Originally Posted by c66vet
(Post 1573042836)
I plan to use pipe thread sealer and install the plugs snug, but was wondering how tight I can go in ft lbs. Thanks "Snug" should be fine. |
Originally Posted by MikeM
(Post 1573048389)
To answer your question, I think your "plan" will work fine. I never install those plugs tight as sometimes, they can be a real b...h to remove. I've never seen one come loose, either.
"Snug" should be fine. Use a bit of teflon-paste as a sealer and to aid in disassembly later. Disassembly normally takes my 1/2 drive breaker bar and a 6-point impact socket. :D Larry |
