Hemi engines
I was wondering what makes Hemi engines so desirable and how they compare to the engine used in the C6?
True Hemi engines haven't been sold by a new car dealer for years.
The current "Hemi" by whatever Chrysler is calling themselves this month is not a true Hemi. The term Hemi meant hemispherical combution chambers and no current engine has hemispherical combustion chambers. The current "Hemi" by Chrysler is such an inefficient design that they have to use two spark plugs to get acceptable ignition. |
The block is a copy of the LS motors...:cheers:
Originally Posted by nwc6
(Post 1573151954)
Originally Posted by haljensen
(Post 1573151811)
The value of the Hemi design over the typical wedge shaped combustion chamber is that the valves are opposite each other at approx. 90 degrees rather than side by side as in the wedge. This allows for a more straight thru intake/exhaust flow, but requires either dual cams or an elaborate rocker arm set up and adds to the engine's overall width, weight, and complexity.
The hemi design was good for it's time of the 50's and 60's but the hemi head/piston design wasn't the reason for the popularity of the Hemi. Those early Hemi's were cast from a high nickel content block with great for the time dimension control/stability AND had forged internals so added power didn't require a new block or heads.
A true hemispherical head calls for a domed piston. Intake and exhaust flow around a domed piston is difficult to control for peak efficiency and power. The current Hemi's use an "almost" hemispherical head and a piston design that requires two spark plugs to get a complete burn. Look at the power produced from the current Hemi, the 10+ year old LS1 design does better on HP per Cubic Inch without a hemi design and without 2 spark plugs per cylinder. The Hemi is/was a great advertising gimmick for Chrysler but not a great advance in power or efficiency. |
Originally Posted by glenB
(Post 1573152503)
They use two plugs because of emissions, not acceptable ignition
With a true hemi head there is much more room to put in larger valves since they are across from each other instead of next to each other and the intake valve port is in line with the intake manifold ports and the exhaust ports are lined up with the exhaust manifold. Nice direct, large ports. To make big power, you need to move a lot of air and big valves are the answer.
Originally Posted by JoesC5
(Post 1573156584)
I don't know anything about the current Chrysler design but the 426 Hemi that I had in my 1970 Dodge Charger was very powerful. It made that automatic transmission, heavy car with 3.54 gears feel light. My 1971 440 6BBL Roadrunner with a manual and 4.10's was a little quicker for about 100 yards but after that the Hemi would walk on away. I actually passed on my first Vette purchase in favor of the RR. It was a 427/390 with a manual and 3-2's. The RR was quicker, which is why I bought it. They were about the same price. What a moron I was that day!
You have an LS based motor. One of the best power producing motors made to date. With very little modification (cam, ported heads) it will pretty much torch anything out there and still get decent gas mileage. No other motor can boast that type of performance and economy. Im pretty dang inmpressed with GM's engineering on this particular application.
The Hemi is the lowest cost V8 Chrysler builds. All Chrysler Hemi's are built in Mexico.
Originally Posted by traderfjp
(Post 1573151594)
all marketing. I have the 5.7 Hemi in my yellow truck in my avitar. they are a lot like our LSx motors. big difference is that chrysler locked down the PCM and very few companies have been able to crack it to allow tuning. compare that with our motors which have a lot of options with tuning tools. I know there are some basic tuning tools out there for the hemi but they do not compare to the ones for our LS series motors.
LS motor CAN make power just by looking at it the wrong way. |
I found this link on how the Hemi engine became so famous and how it's designed.
(Post 1573151811)
The current "Hemi" by whatever Chrysler is calling themselves this month is not a true Hemi. The term Hemi meant hemispherical combution chambers and no current engine has hemispherical combustion chambers. The current "Hemi" by Chrysler is such an inefficient design that they have to use two spark plugs to get acceptable ignition. :iagree: 100% Very well put. The classic hemispherical combution chambers is also a dominant force in professional drag racing today and has been so for many, many years (since the mid 60s) with most top fuel (funny cars and dragsters) running them today still. :cheers: The mystique behind the HEMI engine has a big part to do with the way MOPAR domininted with the Hemi in the the mid to late 60s on the dragstrip and also Nascar Circuit. :thumbs: |
Originally Posted by dads toy
(Post 1573161084)
The ls7 in the VETTE would run rings around the HEMI. HEMI engines have been installed in corvettes for drag racing sand did not work very well.
FYI, my 83 Escort from college had a "Hemi" designed cylinder head. Real performance machine. 'nuf said...
