And We Think Our Vettes Are FAST - LOL - Very Cool Read
DEFINITION OF ACCELERATION
- One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500. - It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels. - Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. - A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger. - With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. - Cylinders run on the verge of hydraulic lock at full throttle. - At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F. - Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. - Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow. - If spark plug momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. - In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's. - Dragsters reach over 300 miles per hour before you have completed reading this sentence. - Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load. - The redline is actually quite high at 9,500 rpm. - Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second. - The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ). Putting all of this into perspective: You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course. Now That's ACCELERATION! |
Still weak..... Can't touch my Stealth fighter (2000mph +) in the hangar. LOL Nice post interesting fact about the Hemi not being able to run the S/C.
You also can't drive it on the street. Why would I want one? :crazy:
It's simply amazing that they can get that kind of HP out of the nitro engines. For those of you that have never been to a NHRA points meet with the nitro burners you owe it to yourself to go at least one time in you life. These vehicles are violent loud and generate a pressure wave you can feel in your chest when they pass by. It's a rush for sure. :eek:
Originally Posted by ZPO
(Post 1573182609)
Simply amazing thing to see, the energy/sound etc... cannot be explained it must be experienced in person to even comprehend. |
