1969 Gauge Cluster Schematic Needed
Hey gang,
Does anyone have a schematic for a 69 gauge cluster handy? It is for a neighbors car, he pulled down the cluster for whatever reason and now none of the gauges work anymore. DUH, I said, probably just a ground wire so I volunteered to help him. I guess I should have looked inside first, LOL. The underdash has soooo much aftermarket garbage wiring spliced in it looks like a 3 year old attempted to make spaghetti. :crazy: Basically, I want to yank the aftermarket wiring that he isn't using and start from scratch to get it back to stock. He ordered a Painless kit for it, but I really would like to have an actual factory schematic and go with that. I haven't had the "best" of luck with some of the Painless kits. I have access to AllDataPro, but it only goes back to 1982 with the subscription I have. Thanks in advance! :cheers: VB edit: Oh and btw, by gauge cluster, I am referring to the temp gauge, fuel, etc. not the speedo area, but if anyone has those handy, I will take whatever I can get. :) |
:cheers:Thank you soo much SpeedReed8!!! :cheers:
That is exactly what I was looking for, you are a life saver!!! If you ever need any info I can pull data from AllDataPro for vehicles 1982 to current. Thanks again!!! :cheers::thumbs::cheers: |
:thumbs:
Originally Posted by speedreed8
(Post 1573252305)
Would you please resubmit it. or send it direcctly to my email. I am having a problem on the exact way the connectors go onto the gauge terminenals. Some will only go on one way. Thanks for your help. Max Naples |
That is great, thanks
I know in wiring, there is pos/neg. which color is is to which pin? Do you have one with connectors connected? Some of the connectors will slip on either way. Thanks Max |
Alan71 might have that picture.
The space between the male connectors is small medium and large and the same on the females so I guess you got the mates together.
The service manual (chapter 12) shows the "U" shaped hole only on one side of the female connectors and the "U" faces the front of the car. |
Originally Posted by Peterbuilt
(Post 1587757731)
The service manual (chapter 12) shows the "U" shaped hole only on one side of the female connectors and the "U" faces the front of the car. Thanks, Just want to make sure not to burn up a gauge, since they we just refurbished. Max |
FWIW: the 69 assembly instruction manual (AIM) shows the cluster connections and lists the color codes. The oil pressure gauge is mechanical.
:thumbs: |
(Post 1587760381)
:thumbs: I will review the AIM, to confirm the color code connections, Appreciate you input Max |
