LS6 intake part #'s
It appears there's various part numbers for the LS6 intake. Can anyone tell me if 12573572 is an LS6 intake? Can anyone tell me all of the part numbers for the LS6 intake?
Thank you. Mike |
The only part numbers for the LS6 intake I know of are the below.
Z06 LS6 12573572 ( I have this one) 01-02 Camaro LS6 12561184 GM Performance part# 88894339 |
its easy to tell weather or not its a LS6 intake.. the LS6 intakes are flat on the bottom.. LS1 are round on the bottom where the valley cover is.
One other thing I just remembered get the LS6 intake without the EGR provision which is not needed on the C5. That was for the 98-2000 Camaro. I don't remember the part number but I think its the same 12573572 ( also used on 98-00 Camaro) number I believe this intake (part #) comes with and without the provision for the EGR valve.
BOTTOM SIDE of a C5 LS1 intake manifold:
http://img.photobucket.com/albums/v4...7/CIMG1047.jpg BOTTOM SIDE of a C5 LS6 intake manifold: http://img.photobucket.com/albums/v4...7/CIMG1110.jpg |
most ls1 intakes have the hole right behind the throttle body, expect the corvettes. you could play a ls1 intake as a ls6 to the right person haha! also like people have stated, ls6s are flat on the bottle.
here are the part numbers for ya. 97-00 LS1 Manifold #12556333 01-02 LS6 Manifold #12561182 03+ #12573572 |
Ls6 intake
Thank you for the information. I've been trying to buy one on eBay. Some of the pictures provided don't show the flat bottom and it's about impossible to tell from the top side. I'm a little shy about buying something I'm not 100% sure of. So again, thanks.
Originally Posted by Bill Curlee
(Post 1573311966)
Originally Posted by kh400
(Post 1573319361)
So theLS1 is rounded on the bottom and the LS6 is flat???!!!!
Yep, LUCKY put the reply straight.:thumbs:
2001+ are all LS6 style intakes. If your LS1 is a 1997 - 2000 it has the hump bottom |
