BackDraft - Breathless Performance 65 Cobra LS2 Powered Supercharged
6 Attachment(s)
Supercharged 402 Stroker LS2 Chevy Engine
Could be daily driven 30 mpg highway about 750 Smooth Horsepower Breathless Performance Company Display Car 1965 Backdraft Chassis with 1965 Title for Antique plates Car comes from BackDraft and Breathless Performance Fully built with a actual vin # This car was built to the highest standards from Breathless Performance as there display company car and has numerous awards in the show car circuit. There is over $80,000 invested in this project and will let the car go for $52,000 She has less then 2,000 miles since built and is kept in our showroom for display. Forget eveything you have so far considered to be typical of muscle cars and allow the BDR Roadster to enter your world. The Backdraft , Breathless Performanc Roadster has been extensively developed and refined over many years as a proven, high-technology, superior quality sports car. It provides the ultimate in authentic replication, quality finishing, advanced ergonomics and passenger comfort in a roomy interior. It offers lightning quick performance, sure-footed handling, compliant ride comfort and excellent braking ability in a well rounded package that is unrivalled for quality and value. Engine New Custom Built LS2 GM Head and Cam package with D1SC Procharger supercharger. Engine still uses GM computer system for super reliable package. Can be plugged into any GM teck2 computer to read data. You still get over 30 MPG on the highway and pump out close to 750 HP. Transmission is a built tremic 6sp to handle all the power. Body After the body has cured in the mold at an ambient temperature, it is removed and inspected before being prefitted to the chassis. The body is then transferred to our state of the art paint facility, where it undergoes a rigorous quality inspection prior to any preparation. Any areas of concern are addressed before the paint preparation procedure starts. Paint The initial phase of the preparation involves the body being filed down and filled wherever necessary. The body is then primered which is post cured in an oven at 75 degrees Celsius for one hour. After the body has cooled it is then dry-flattened before it is presented to our quality control for inspection prior to the paint application. Before the paint can be applied the body receives a final check coat. After the check coat has been inspected the body is ready for the application of the final color. The base coat is followed by three layers of PPG clear coat before the car is baked again at 65 degrees Celsius for one hour. After the body has cooled in the oven it is removed and left for 3 days before being flattened and polished to a high gloss. After the body passes the paint work quality control it is moved over to the final assembly facility. Suspension The ladder-type chassis is fabricated in a jig from SAE 1008 2' x 4' hot rolled rectangular steel tubing, with a 1/8” wall thickness, which provides a sturdy chassis, both in beam strength and in torsion rigidity. The chassis is reinforced with laser cut steel gusset plates in several areas for added strength and to rigidize the chassis in high stress areas. The chassis has been designed to accept a race proven independent rear suspension with coil over struts in the front. The differential is fully rubber mounted to the chassis in a cradle, eliminating mechanical differential noise and providing a smooth drive. In the final manufacturing phase, the chassis is ground and sandblasted as preparation before it is epoxy powder coated for protection from the environment and added visual impact.The chassis is powder coated using a polyester VX powder applied at 40-60 microns. This ensures that your Backdraft , Breathless Performance Roadster is pleasing to look at even under the skin and adds to its durability and lifespan. It also eases under car maintenance and cleaning. The car comes equipped with a custom fabricated gas tank. The gas tank is made from Rotomoulded Polyethylene and has a capacity of 18 gallons (70 litres) Steering The car comes standard with a rack and pinion type steering system. With our optimal weight distribution in the car and a steering ratio of 4 turns lock to lock, power steering is not necessary. The steering column is made from high quality stainless steel tubing connecting to a CNC machined billet aluminum steering boss. The car can accommodate a power assisted steering on special order. Front Suspension The front suspension features cast lower wishbones with a coil over strut. The strut has been custom fabricated to suit the needs of the Backdraft, Breathless Performance Roadster. We also use a stabilizer bar which assits with the overall fine tuning of the car's handling Rear Suspension Setting the power safely to the ground is handled by a centrally guided multilink rear suspension. The suspension is fully height adjustable which makes it easier to fine tune for street and track use. The suspension has proven itself both on and off the race track. In conjunction with the front coil over struts you are guaranteed a thrilling driving experience Brakes The roadster features power disc brakes on all four corners. The front brake discs are 310mm(12.2 inch) in diameter and the rear is 295mm(11.6 inch). Both the front and the rear come with ventilated discs as a standard option. The calipers used are all single piston calipers supplied by ATE. The calipers are fed from a vacuum assisted booster with a dual stroke master cylinder. Wheels The wheels are a Halibrand style aluminum knock off one piece,: Front: 17" x 8.5" with a 235/40 x 17" GoodYear F1 tire Rear: 17" x 10.5" with a 315/35 x 17" GoodYear F1 tire Interior The cockpit of the car features 60's styling combined with modern day efficiency. The car comes fully carpeted with a high grade carpet. Overlay mats with bound edges are a standard feature in the cockpit. The seats come upholstered in high quality leather. The driver’s side seat comes standard with an adjustable seat slider. The interior of the car is not only fully functional, but it is also comfortable and can accommodate a taller driver (in excess of 6”). The interior is completed with a wood rim steering wheel, self canceling turn signal and a full complement of 7 instruments. The instruments featured in the roadster are all electronic which have proven to be more accurate and reliable. The important instruments are easily visible. With the fuel tank located underneath the luggage compartment floor, the Backdraft, Breathless Performance Roadster offers very usable luggage space that can easily accommodate a weekend’s luggage for two or your weekly groceries Exhaust Precision crafted mild steel headers with polished aircraft quality 304 stainless steel side pipes come as standard equipment. Stainless steel exhaust heat shields are also standard equipment on the backdraft roadster. These are custom made for the car and can be ceramic coated as an option Roll Bar The car comes standard with a stainless steel driver side roll bar, which comes mounted to the frame. The roll bar is made from grade 304 stainless and then it is completed with a high polish. This is a fully functional 2 piece unit. Custom stainless steel/rubber trim rings are used to complete the installation of the roll bar Only $52,000 Link: http://breathlessperformance.com/Used&DemoParts.asp Ernie www.BreathlessPerformance.com 954-925-7725 |
That's great I'd bet it's violently quick.
Yes you better believe it..and reliable too.
Ernie |
