My 347 build complete (56k=death)
Well I finally have the car fully put back together & running STRONG!! This was a big winter project that I have been waiting and waiting to do. In August my wife & I finally found a house and I was lucky enough to have the time and resources to pull the motor and build a forged bottom end.
So let me first start of by showing you what the car looked like before I started the tear down. About 5 years ago right after I installed Andy’s P1 kit http://i948.photobucket.com/albums/a...g?t=1268151446 This past Oct. right before I parked her and started the tear down. http://i948.photobucket.com/albums/a...g?t=1268151480 Motor build 347ci Diamond -8.6cc Forged pistons Diamond rings K1technology rods ARP 2000 rod bolts ARP head & main studs Stock crank SC3 cam (226/234 .598/.599 117+2) Manely double roller timing chain LS6 oil pump LS6 heads 60# injectors Patriot dual springs Yella Terra rockers LS6 intake OBX LT headers Magnaflow cat back And so the fun begins…. http://i948.photobucket.com/albums/a...g?t=1268151686 Motor OUT!!! http://i948.photobucket.com/albums/a...g?t=1268151756 http://i948.photobucket.com/albums/a...g?t=1268151789 Original block & pistons (in really good shape for 85k) http://i948.photobucket.com/albums/a...g?t=1268151904 http://i948.photobucket.com/albums/a...g?t=1268151929 Forged Bottom http://i948.photobucket.com/albums/a...g?t=1268151972 http://i948.photobucket.com/albums/a...g?t=1268152029 http://i948.photobucket.com/albums/a...g?t=1268152084 Assembly time, Me in the black shirt, Lt. Dan in the white shirt http://i948.photobucket.com/albums/a...g?t=1268152192 http://i948.photobucket.com/albums/a...g?t=1268152257 I put my motor in from the bottom already on the cradle & just used a motorcycle jack to lift it up in place. http://i948.photobucket.com/albums/a...g?t=1268152291 http://i948.photobucket.com/albums/a...g?t=1268152360 Some of you may know that guy in the middle, Fartpipe from the forum http://i948.photobucket.com/albums/a...g?t=1268152459 Up next is the mock up of the laid front intercooler & radiator. http://i948.photobucket.com/albums/a...g?t=1268152579 http://i948.photobucket.com/albums/a...g?t=1268152604 http://i948.photobucket.com/albums/a...g?t=1268152680 http://i948.photobucket.com/albums/a...g?t=1268152728 http://i948.photobucket.com/albums/a...g?t=1268152798 http://i948.photobucket.com/albums/a...g?t=1268152853 http://i948.photobucket.com/albums/a...g?t=1268152918 |
http://i948.photobucket.com/albums/a...g?t=1268152951
http://i948.photobucket.com/albums/a...g?t=1268152981 http://i948.photobucket.com/albums/a...g?t=1268153023 http://i948.photobucket.com/albums/a...g?t=1268153080 Now for some of the small touches http://i948.photobucket.com/albums/a...g?t=1268153197 http://i948.photobucket.com/albums/a...g?t=1268153232 http://i948.photobucket.com/albums/a...g?t=1268153356 http://i948.photobucket.com/albums/a...g?t=1268153378 BACK ON THE ROAD!!! http://i948.photobucket.com/albums/a...g?t=1268153433 So it was a fun project, with some minor things to finish up on. Such as the tune and washing the poor thing. I can’t thank you guys on the forum enough, I have been a member here for a while and have just been taking in all the information put up. BlownBlueZ06 has been a SAVIOR w/ helping me tune the car. Fartpipe has been a huge help in coming over & helping get stuff back together. Lt. Dan isn’t on the corvetteforum, he is on LS1Tech and has a blown Firehawk, and has also been a big help in everything. Reido is my professional photographer, you can def. tell which pics he took. No dyno number yet, I just had the car out Saturday to go down to Cecil, just for some break in miles. She runs strong, and I can tell there is a lot more grunt w/ the better heads & cam. As soon as I get her on the dyno I will let you know what kind of #’s I put down and maybe I’ll make my way down to Cecil for some time slips this summer. |
Interesting way of mounting the rad and intercooler
Very nice :thumbs: and great progress:D
But isn't the going to grab "HOT" air through the radiator instead of Cold air? or are you gonna drop the filter down lower? Just wondering :thumbs: Thanks,Matt |
Originally Posted by madmatt9471
(Post 1573359763)
Looks good. We you running meth on the old setup? Those pistons look awfully clean :)
How did you get the front high enough to roll the engine in and out? |
Originally Posted by C5kid
(Post 1573359824)
I just have the filter on the end right now, I am goin order some alum. pipe and fab up a intake system to get teh filter down away from the rad. to suck in cold air.
There is one absoloutly awesome thing I like about your set-up and that is the amount of room it gives in front of the motor - Which air dam did you use - Stock or Madified (Home made like me)? Thanks,Matt |
(Post 1573359863)
XLNT! Before the Dyno Day:D If I may suggest, it'd be worth it :thumbs:
There is one absoloutly awesome thing I like about your set-up and that is the amount of room it gives in front of the motor - Which air dam did you use - Stock or Madified (Home made like me)? Thanks,Matt I do like the amount of room infront of the motor, and getting the radiator & intercooler away from the motor heat. |
Originally Posted by user_name
(Post 1573359830)
How did you get the front high enough to roll the engine in and out? To pull the motor outta the bottom I had the entire car up on jack stands. I measured how tall the cradle to the top of the intake was & how tall the motorcycle jack was & just made sure my front frame rail was an 1" higher. I also had the tranny out. I doubt you could do this w/ the tranny in the car yet. Worked PERFECT. I dropped the motor out myself, I had Deb hang around in the garage in case something started to go wrong. |
Originally Posted by EVLZ06
(Post 1573359670)
Wish I would have tought of that. It would be some extra work and money for me because I got the old twin intercooled setup but I like your radiator and fan setup a lot. Very Nice! (edit) Now I'm just pissed off I didn't think of this. A cam change looks like about 1 1/2 hours with this set up and 2 piece timing cover. I have not seen any other pictures of this done that way. That's it I'm going to the garage... |
looks good - just one comment....
I think the Top Rad hose really stands out with the way you have it run... have you thought of running it along the front of the motor and 90 degree's to the radiator. Just may clean up the look. |
Very, very nice!
Originally Posted by SmoothFRC
(Post 1573360522)
Looks great! Would love to see some dyno #'s and maybe a sound clip.... :D
Congrats on the new motor. Good chance we will meet at Cecil one day.
Did you really let Fartpipe work on your car? :willy: :lol: |
Originally Posted by 4DRUSH
(Post 1573366488)
Everytime I see a C5 w/ the radiator laid forward it makes me wonder why they didn't do it that way from the factory. Danny Popp does this on his NASA ST1 road race car and they do it w/ the GM C6R race cars... it allows vented hoods to be sealed to th radiator and be fully functional.
Very nice.:thumbs:Let us know what temp it runs at during the summer.You might even get away with the stock rad.
Good luck. |
Looks great. I grabbed these pictures off one of the race vettes up at Kerrys (ACP) that had similar radiator set-up
http://i61.photobucket.com/albums/h7...s/IMG_0981.jpg http://i61.photobucket.com/albums/h7...s/IMG_0980.jpg |
Yea, I really like the way the laid down radiator worked out. There is a good chance I am goin to put on a MCM hood. That will really help to get the air flowing through the engine bay.
