TVS 2300 and C5 hood options
Has anybody found a hood that works yet? One post said the RK sport hood works. What about the caravaggio? magnaextractor?
Also, someone apparently has the tvs1900 on a c5...can you give us some idea of what kind of clearance you have? |
:lurk:
Originally Posted by Zo3o6
(Post 1573408107)
:lurk:
Im currently working with a member on this forum to see if the caravaggio will fit over the 2300. I'll keep you gusys posted....
I have the 2300 on my C5. RK sport hood must be cut at the top near the firewall and it rubs slightly on the bridge.
I hate to bump this but yellow Z, did you put this hood on your car? I am in need of a hood and the RK hood looks really nice and lower than the lingenfelter or the carvaggio but and concerned about clearance. We, Being my dad's car, just got the tvs2300 installed and tuned and now are in desperate need of a hood. A little trimming is no big deal, but the blower does stick up a lot in the front near the TB and air bridge. Just looking fro confirmation before buying it and having it not work tomorrow.
how many 2300 kits are out there for the C5?
Well anything that will fit the KB's should fit the TVS's. I have a VIS Carbon cowl myself..
I have the Lingenfelter hood on mine. It fit, but under speed it pressed down on the rear pulleys. Last I heard, they were going to modify it, but it really wasn't that big of a deal to make it work. Keep in mind, this was originally designed for the MP 112.
Here's a few random shots to show the different angles. :) http://i220.photobucket.com/albums/d...19/9856563.jpg http://i220.photobucket.com/albums/d...9/78952562.jpg http://i220.photobucket.com/albums/d...reet19/6-2.jpg |
Sorry, I meant to add these, too.
http://i220.photobucket.com/albums/d...reet19/2-6.jpg http://i220.photobucket.com/albums/d...reet19/c5z.jpg |
Originally Posted by TRDon
(Post 1577369980)
I am running the RK sport but you have to cut out a portion of the hood for the pulley near the fire wall. It also rubs on the air bridge, however, you might be able to fix this problem with some trimming and work to lower the bridge. I picked up my hood pretty cheap and I plan to have it repainted in the future so I have not focused on trying to fix these problems. The cut out portion near the firewall I think can be remedied fairly easily. I dremeled out a portion of the hood for clearance and in the future I will flip over the cut out portion and reinstall it with some fiberglass work. The rubbing on the bridge is enough to rub off the paint, but it is very possible that I will be able to fix this in the future. I just have not had time to look at it yet. I really like the lower profile look of this hood. |
Originally Posted by Yellow Z
(Post 1577431987)
Back from the dead.
Does anyone know if the ACI radical hi rise hood will work with the TVS2300? I'm sure notching the rear is required but I'd be worried about the front of the snout more than anything rubbing the hood. |
I have a caravaggio on my 02Z. Like the others, it has to be cut out at the back for the pulleys.
seems like a pretty old discussion, but i'm surprised i missed it all this time.
the Kenne Bell hood fits with no cutting and has factory lines - just taller. TPE was the last people i know of who sold it. |
