CAI for Maggie 122
Decided to roll with the 122 and have install set for Tuesday. I had planned on using a Vararam cai but was just informed this would not work or fit? are the only candidates a lpe and honker? Thoughts please as I have 3 days to get the right one delivered. :willy:
I had a Vararam when my M112 was installed 3 years ago (didn't fit).
I went with the LPE.............LPE and Callaway are the only 2 that will work (as far as I know). |
Thanks! OK...vararam with 5000 miles is now for sale.
Wtb honker! :) |
Wtb honker! :) |
What? Are you kidding me? Why not just modify the VaraRam to fit.....cut it, sand it down.....do whatever it takes to make it work.....couplers, etc, who cares.....just make it work, you probably won't regret it.....cold ram air is tough to beat.....just do it!
Originally Posted by HuskerBullet
(Post 1573580833)
It can be done, I guess I should have elaborated.........but there are 2 problems. The intake of the Magnuson is offset, I know someone that made it work after much effort (only to change it to a Honker later). And the biggest problem is the Vararam would not stay sealed (between the 2 halves). Unless they have made BIG improvements to the Vararam over the last year, I would not buy another. I (and many others I've talked to) could not keep the Var sealed for any length of time and the different angle of the Magnuson inlet made it worse. I think the forced cold air of the Vararam would definitely be the way to go.........if you could get it to seal properly. |
Purchased the honker fitted for the Maggie today. ..more then I wanted to spend but it's will fit and look tight.
Originally Posted by DEODELTA
(Post 1573583753)
Originally Posted by Bushong572
(Post 1573582627)
Now that we're in 2014, what is a proper air filter for a maggie 122?
