Originally Posted by supervette64
(Post 1598057513)
18x10s all around with 285/35R18 tires. Torq Thrust II in gray. 5.6" back spacing if I remember right. I have small spacers (10mm I think?) because the rears were very close to the frame and would occasionally rub. Offset trailing arms as well.
https://cimg5.ibsrv.net/gimg/www.cor...f7de2c480e.jpg https://cimg6.ibsrv.net/gimg/www.cor...1ae56c2941.jpg https://cimg9.ibsrv.net/gimg/www.cor...2de2a9bd39.jpg https://cimg5.ibsrv.net/gimg/www.cor...68a7af64f0.jpg https://cimg0.ibsrv.net/gimg/www.cor...7e51c0ff45.jpg https://cimg2.ibsrv.net/gimg/www.cor...edf148c1ab.jpg https://cimg6.ibsrv.net/gimg/www.cor...f473839da6.jpg |
Originally Posted by Metalhead140
(Post 1598057793)
Those look familiar! These are my track wheels, 18x10, 5.74" backspace with a 0.1" spacer for an effective 5.64" backspace, 295/30R18 tyres.
(Post 1598068484)
Looks great! Which 295/30R18s do you run at the track and how do you like them?
https://cimg3.ibsrv.net/gimg/www.cor...f4461c681f.jpg |
Torq thrust ll rims
Hello all, I read and read and just want to confirm before I pull the trigger. Will torq thrust ll rims fit my 1969 Corvette with no modifications? Here are the measurements they are giving me.
18x8. Offset 0 mm. 4.5" backspacing. (Front) 18x9. Offset 0 mm. 5" backspacing. (Rear) Quoted price $1126 shipped to my door Any help would be greatly appreciated |
Originally Posted by JBrooke825
(Post 1605255918)
17’s
https://cimg8.ibsrv.net/gimg/www.cor...fdcfa5318.jpeg https://cimg9.ibsrv.net/gimg/www.cor...d2d8219ae.jpeg |
17's on the litter box. 17 x 8 (o off set 4.5" bs) and 17 x 9 (o offset 5"bs)
https://cimg6.ibsrv.net/gimg/www.cor...1605b38650.jpg https://cimg7.ibsrv.net/gimg/www.cor...562f0d17b0.jpg |
Oddly enough just joined the club a couple of weeks ago
https://cimg3.ibsrv.net/gimg/www.cor...8cc013f22a.jpg 17x8, 4" BS 235/55 R17 Continental DWS M |
Rear. 255/50/17
front 245/45/17. |
17's with Nitto 555GT tires......BIG DIFFERENCE in handling and ride. Will never go back to 15's.
https://cimg4.ibsrv.net/gimg/www.cor...0d6b49b178.jpg |
That's a very nice looking car :cool:
M |
That is also a very nice looking car :cool:
M (OK I'm also a bit biased on that one) |
Originally Posted by Mooser
(Post 1605260288)
I'm sure someone will check in who's done it and I believe it's been done, I think you'd still have to be careful of the parking brake bracket on the arm / cable with the extra 1/2" of BS.
My wheels are currently off again so when I put the rear back on I'll check clearance on the arm though and report back M |
Not on 17 inch or bigger wheels due to the wheel, but now you would have to look at the tire getting close to the cable. The hanger will be into the dish of the wheel. The tire clearance on the spring and spring bolt needs to be addressed as well
(Post 1605274106)
Originally Posted by Laws69cars
(Post 1605274476)
On a 69 vette would you know if a 4.5" backspace will work or is it best to stay 4" on a 17x8 rim?
My tires are 235/55 almost exactly 10" wide at the bulge and measure in from the bulge to the mounting surface of the rim 4-5/8 ~ 4-3/4" depending on my paralax My parking brake is relocated to the top but it looks like the bracket would be inside the rim lip be a little so it would clear Between the tire and the trailing arm I can just put a 1-5/16" wood block and it sticks so probably about 1-1/4" Keep in mind my parking brake cable isn't there so it's probably about 1/2 ~ 5/8" out from the arm so that would take the clearance down to 5/8" ~ 3/4" which doesn't seem too bad with the 4" BS Looking at mine, going to a 4.5" BS would seem pretty tight to the parking brake cable if it was in the original spot and if you went to a wider tire (like a 255, assuming using the same 8" rim) it would get even tighter I was thinking someone who's tried it would chime in Anyway, that's what I see on mine, YMMV (the rear sway-bar is actually slightly closer but the wheel is hanging down and I think it will more away some as it comes up so I don't think that's an issue) M |
