Coilovers Installation (Rears).
Updated 10-20-2017
Posted the same photos because Photobucket and the can go a fuck themselves. The procedure was removed in 2011 and I'm not going to write a 1,000-word removal & installation instructions, sorry. Here are the photos, you'll need tools of all types, and this is not a beginners' task. https://cimg4.ibsrv.net/gimg/www.cor...13858901d1.jpg https://cimg7.ibsrv.net/gimg/www.cor...963200a111.jpg https://cimg8.ibsrv.net/gimg/www.cor...05f77f9c55.jpg https://cimg9.ibsrv.net/gimg/www.cor...fbee212ca3.jpg https://cimg0.ibsrv.net/gimg/www.cor...80d82a46f8.jpg https://cimg1.ibsrv.net/gimg/www.cor...b36c99f90c.jpg https://cimg2.ibsrv.net/gimg/www.cor...0e9fe11173.jpg https://cimg3.ibsrv.net/gimg/www.cor...3331df9646.jpg https://cimg4.ibsrv.net/gimg/www.cor...ae11fa9cf4.jpg Van Steel sells an updated shock bracket. The newer kits he sells come with it. The OEM bracket will not work. https://cimg5.ibsrv.net/gimg/www.cor...0b5fb51e9d.jpg using the OEM bracket allows the coilover to rub the half-shafts. |
Very Nice :thumbs:
Im jealous. That might be my next mod.
:thumbs:
Originally Posted by 96GS#007
(Post 1573794119)
:thumbs: That the Exotic Muscle setup?
Originally Posted by PLRX
(Post 1573794137)
Van Steel
Nice! Looks great!
How did you get the tire carrier off? I wanted to take it off one day to clean/polish the aluminum back there but I couldnt get the bolts off the black frame piece that holds the L-shaped bolt/nail shaped things that the tire carrier slides on. Is there another way? :cheers: How does it feel compared to the spring? |
Awesome thanks for the write up. If I keep this car, I am doing coil overs too.
Originally Posted by dogfish246
(Post 1573794192)
Nice! Looks great!
How did you get the tire carrier off? I wanted to take it off one day to clean/polish the aluminum back there but I couldnt get the bolts off the black frame piece that holds the L-shaped bolt/nail shaped things that the tire carrier slides on. Is there another way? :cheers: How does it feel compared to the spring? The spare cant be used anyway it is 14 years old, cant get a new one and I got C5 brakes in the front. |
(Post 1573794217)
Using a flat screwdriver I bent the carrier's aluminum bracket. :thumbs:
The spare cant be used anyway it is 14 years old, cant get a new one and I got C5 brakes in the front. Thanks! |
PLRX- always entertained by your threads! Thurough write up, awesome pictures, very informative!
So asdogfish246 asked- how does it feel? I noticed that you went with the dual adjustable dampers. please tell us what the reasons are that you went with Van Steel over the other vendors? |
Originally Posted by mnstrlt1
(Post 1573794710)
So asdogfish246 asked- how does it feel? I noticed that you went with the dual adjustable dampers. please tell us what the reasons are that you went with Van Steel over the other vendors? Brian suggested Van Steel and the modifications are minors. |
(Post 1573794021)
I'm assuming ride height is adjustable based on the threads on the shock base(?) Great work, as usual! :thumbs: |
Originally Posted by RUU
(Post 1573797225)
You should have Photoshopped the scrapes out of the exhaust before posting - now we're all wondering what you ran over. :crazy:
Very nice, but the spring bolt carrier looks strange with no bushing in it - maybe a place to set your beer next time you do the rear brakes. :) I'm assuming ride height is adjustable based on the threads on the shock base(?) Great work, as usual! :thumbs: It didn't look right without bushings, I called Van Steel on Friday and they confirmed it goes the way it is in the picture. Yes, the ride height it's adjustable. |
(Post 1573796391)
I haven't driven the Vette yet and the front is not done yet.
Very nice Pete and good job as usual. :thumbs:
What is it about the Van Steel rear coilovers that allow installation without modification? Is it the Hard Bar top pin mounts?
Extremely clean C4, very well done! The lower rear mounts as well are Hardbar designs, licensed by VanSteel. I really wish I had these when I had my '89. Some of these parts, like the upper mounts are exactly the same as we supply on $6000 triple adjustable Penske coil overs for C6Z's and ZR-1's.
Who sells the lower besides Van Steel?
I gave up on waiting on the lowers, evidently they are available now. |
Originally Posted by ninetyfivevette
(Post 1573799230)
