Bad or wrong Spark plug cause hissing sound
I just got my car diagnosed by Chuck at COW (they are great by the way) for a hissing sound from engine bay and I was just told it was due to a bad spark plug or wrong spark plugs.
Originally Posted by uptown193
(Post 1573991377)
I just got my car diagnosed for a hissing sound from engine bay and I was just told it was due to a bad spark plug or wrong spark plugs.
Is this possible? Maybe the wrong spark plug wont sit properly in the head so there is air moving in and out???:cheers: |
Originally Posted by dogfish246
(Post 1573991560)
When I hear hissing the first thing I look for is vacuum lines that are loose, cracked, or completely off. Then I look for any looseness in the intake, exhaust leaks, and try to go from there.
unfortunately I did have the sound you described. it was a cross threaded spark plug.
Originally Posted by Harsh20
(Post 1573994035)
(Post 1573994035)
The person did install new Splitfire spark plugs. |
If the plugs are cross threaded, then they would not be properly installed.
If the plug is not "sealed" with the head, combustion pressure can escape creating a "hissing" sound. Your engine is just a large air pump. Leaks on the intake side will be sucking air into the system, and leaks on the exhaust side will be pushing air out of the system. A spark plug not properly sealed will have both of these effects (depending on what cycle the piston is on). |
My O2 sensor was causing my hiss or fphtttt...fphtttt.sound .I swear I thought I had a bad rocker arm.Just so you know...
Originally Posted by RollaMo-LT4
(Post 1573997365)
Originally Posted by Sparkostatic
(Post 1574005733)
(Post 1573996075)
When you say cross threaded do you mean that the plug was not properly installed?
The person did install new Splitfire spark plugs. short story is that i ended up replacing the head. |
Here's the deal.....
(Post 1574006750)
Yea that is how mine sounded. Well COW diagnosed it to be the spark plug, he says it runs 10 time better. Let see... Thank you...
You have an aluminum headed C4 engine. They use LONG REACH GASKETED plugs. The dick you took your car to the last time for it's spark plugs cross threaded the #2 spark plug hole trying to put a SHORT REACH, NON GASKETED (taper seat) PLUG into a car that dosen't use one. You're lucky the head didn't have to come off. For anyone that has worked on a C4 with the stock exhaust manifolds and air pump check valve and plumbing on the passenger side between (angled) plugs #2 and #4 KNOWS FULL WELL that it takes divine intervention to get that spark plug threaded correctly and snugged down with all that emissions crap in the way. Be thankful that he didn't do any more damage than he did.:thumbs: It seems to be running much better from what I see, but I'll take it for a ride tomorrow and evaluate it more. I haven't seen this car for a year or so, I wanna look it over carefully. BTW...That new paint job sure does look nice! Chuck CoW |
Ohhh ok Chuck sounds awesome. That is why I am only bringing my car to you. You sure do know what your doing, hands down, unlike some of these other mechanics out there. Thanks again.
At least the paint job came out nice. Btw nice video. |
(Post 1574009282)
(Post 1574009383)
Your lucky you have a good mechanic near you! I have to go all the way to Corvette Paramedics if I need something done!
(Post 1574009611)
Yea I know right. It is amazing how important it is to find a mechanic that mostly works on Corvettes. He is a straight shooter too. He tells you how it is and will end up. Well I hope the travel time to your mechanic is well worth it as well. :cheers:
(Post 1574009772)
Yeah, haven't had to use them yet (knock on wood) because I do most of my own work, but its good to know if I cant fix it, I can take it to them! :thumbs:
GJ Chuck :thumbs:
Yea man god bless COW.....
Found that coolant leak.......
Found that coolant leak.......on the test ride....That you forgot to tell me about....:toetap:
We're diggin' in right now. More on this later today. Chuck CoW |
