And so it begins....
The turbos, wastegates, and blowoff valves arrived today. Precision billet 82mm turbos and a 6 speed should make for a different experience. More pics to come as build goes on.
http://i300.photobucket.com/albums/n...82mmTurbos.jpg |
Never enough...I like it.
I'm curious to see how the 6speed conversion goes. I've heard its a nightmare. However, I'm sure Josh and crew have you covered. :thumbs:
Are you going to use the exhaust logs from your APS kit and make those turbos fit? If so, HOW? :)
The 6 speed conversion isn't too horrific... |
Originally Posted by EdwardETraylorIII
(Post 1574075164)
OK, COOL! Makes sense! No way those turbos would fit where the APS kits puts them...
I think your new set up will readily claim the new Corvette Mile Record!:thumbs: |
Thanks for selling my customer the 4L80 swap. We have 3 4l80 C6Z's in the shop right now haha:thumbs:
Originally Posted by Frans96ss
(Post 1574075798)
This will make a new record in C6 history soon!!!
Can't wait to see it RC!!! |
Originally Posted by BADZ
(Post 1574075869)
Can't wait to see it RC!!! I think it will make a record in the Corvette history not only C6 :eek: RCC Do you think POWELL can comment about his Porsche and get this thread locked too?? :lol: Good luck with the build man I can't wait to see some Tx Mile runs. |
RCC sick setup. I'd like to see it take down SW's TT Lambo. Now that would be the ultimate street car match up.
No offense SW. Your a cool guy. |
(Post 1574075869)
Originally Posted by RCC
(Post 1574075198)
LMR is building custom headers and locating the turbos in the fenderwells, very similar to the HPP kit. Converting the car to a TR6060 after doing a 4L80 conversion will be a piece of cake.
the 4L80 can't handle the power or what? |
Originally Posted by FreakC6ZO6
(Post 1574082451)
Why go from 4L80 to 6speed?
Sounds like a great continuation of your project.
With fender mount approach, are you planning on trying to run piping so it does not run under frame? Also any plans to support turbo's overhung load (tendency to droop/crack over heat/cool cycles)? Sorry for all the questions, is 6060 the ZR1 unit as the gears are supposed be stronger do to better metallurgy. Well good luck with it, I'm sure you'll set the bar a notch higher :thumbs:. :cheers: Mike |
Originally Posted by Skunkworks
(Post 1574083377)
:eek:Sick bro, keep us posted:thumbs::cheers:
(Post 1574084005)
The 6060 is in the ZR1 and ZO6. Im using the ZO6 trans because its gear rations are wider which will mean longer pulls without shifting on my new turbo setup.
What about 5th gear? won't slow u down? Goodluck |
(Post 1574086558)
U will keep stock ratio on all gears?
What about 5th gear? won't slow u down? Goodluck I'm 100% sure 5ht wont be a problem with anything over 600rwhp imagine 1500rwhp .... But if he went to Texas-mile I think he needs 27+ tall tires to run 240+MPH :eek: 6th gear is useless |
(Post 1574086558)
