Let's See Some 315's From The Rear
Hey guys,
I'm going to be buying some AFS ZR1 polished replicas within the next week or so, and I was wanting to see how much the tires are going to stick out past the fenders. Let's see em :cool: |
Originally Posted by RedLS1GTO
(Post 1574251906)
Ask COPO, I think he is going 355 or something crazy. (shortend rear)
Originally Posted by 94lt1vette94
(Post 1574252149)
Those look perfectly flush :thumbs:
They'll sit flush, just go with about 1.5 degrees of negative camber in the rear and they're perfect. If you go with typical alignment shop specs 0-.5 +/- they'll stick out.
When I took my car to the alignment shop, I just eyeballed it flush while the tech was moving the camber adjuster in the rear. Once flush, I just told him to hold it there. It ended at about 1.4 neg in the rear and was inline with the VBP suggested baseline "handling" settings. |
Originally Posted by jdc
(Post 1574255871)
http://i211.photobucket.com/albums/b...dc/test281.jpg
http://i211.photobucket.com/albums/b...c/100_5156.jpg |
Do the 315's have room on the inside? If so couldn't you use a higher offset wheel to help tuck them??
OR Are they a way to "mini tub" or possibly shorten the rear axle. I would really like to to run 315's but don't want the skated look. |
Originally Posted by lushdrunk
(Post 1574256424)
OR Are they a way to "mini tub" or possibly shorten the rear axle. I would really like to to run 315's but don't want the skated look. Below, you can see how much travel you will have even with a VERY stiff suspension. Just because you may have clearance sitting still doesn't mean you will when things are moving. Compressed... http://i126.photobucket.com/albums/p...r/MKS_1835.jpg Extended... http://i126.photobucket.com/albums/p...r/MKS_7246.jpg |
Originally Posted by arctic 92
(Post 1574254185)
(Post 1574255871)
(Post 1574257167)
How do they wear with that much camber?
Wear is really more of a toe issue. Yes, your placing a little more pressure on the inside of the tire, but in turning the tire is becoming more evenly loaded. It's nothin to worry about. |
http://i46.tinypic.com/mkw46o.jpg
http://i49.tinypic.com/2mzwciq.jpg http://i50.tinypic.com/rlg6td.jpg 315 goodyears with a 45m offset |
Originally Posted by mnstrlt1
(Post 1574257304)
http://i666.photobucket.com/albums/v...5/IMG_3627.jpg
http://i666.photobucket.com/albums/v...5/IMG_3624.jpg http://i666.photobucket.com/albums/v...5/IMG_3586.jpg 315's rear, 255's front. Quick question for you guys: Should I buy the AFS wheels with the cheap Sumi's or the AFS wheels with the more expensive Vredestein package? I've priced both tires, and for $100 more, I'm really getting $400 more worth of tire. What do ya'll think? |
