Can you feel the difference with a tune?
I have an appointment for a dyno tune in a couple of weeks. I just installed headers, and this weekend I'm installing an Airaid intake and a 160* T-stat. It a manual trans. LS3. Will the tune make a noticeable change?
The headers alone, untuned, FEEL much faster, but it is also louder and that could be decieving. |
Definitely. In fact, if it does not feel faster all around the tuner does not know what he's doing. (Which does happen, so cross your fingers).
It's really hard to believe, but a tune makes all the difference. I only have headers and intake, and I tune my own car using HPT. Even though, you may think your car runs fine without the tune and mild mods, you'd be surprised what a scanner can tell you about how your car is actually running.
Originally Posted by tomiboy
(Post 1574489082)
I noticed it used to burble nicely on decel with the NPPs open, now it's actually backfiring occasionally. I would assume a tune will remedy this. It also set off a CEL within a couple of short drives.
The tuner is Dan Bills at FLP in Naperville Il and comes highly recommended by the guys in the Great Lakes forum. It was a three week wait for an appointment with him |
(Post 1574495074)
So, how did the header install go? Run into any snags? |
It was my first header install and went pretty smooth. I'm 58, if I can do it anyone can. I did it on 6" ramps up front and jackstands in the rear! The headers are loud with the NPPs open but good loud! They backfire occasionally on deceleration now, before they just burbled nicely. I believe I read a tune will get rid of some of that.
I was told he will dyno and street tune but I don't know the order. |
hmmm, gives me confidence to maybe even think about trying it myself.
He will street tune it first. You want to get the fuel trims in check and have a good base tune before strapping it on the dyno. If you could, let me know how it all goes and what your dyno numbers are. Are you going to be doing a baseline pull before he tunes it? |
Tune made a world of difference for me.. Can't wait to see your results...
I don't know if he'll do a baseline first. I'm having my sons drop it and pick it up. So I won't even be there.
Do you have a hydraulic floor jack that will fit under the back end and some ramps for the front? If so, and some very basic hand tools, you'll be fine doing it yourself. It did take me 8 hours on Saturday and a little more on Sunday!! I probably would have done it in a day easy if I was younger! Climbing under, or out from under,the car a zillion times when I forgot something was killing me. When I had questions on Saturday I called LG and they told me what to do. |
yeah, I have plenty of tools; one professional low profile jack, 4 other standard jacks, a set of Rhino ramps and 2 sets of jack stands. I had to make some "pre-ramps" to use with the Rhino's in order for the Rhinos to clear the front bumper cover. I've had my car up in the air a few times already. Once to change out my tranny/rear end fluid and once to clean the whole car top to bottom when we got back from a 4,500+ mile road trip out west. Here's a pic of it in the air after I got it pretty much cleaned up:
http://i307.photobucket.com/albums/n...9/DSC07270.jpg |
I wish I had that much room!!
yeah, it's nice but it sucks having a gravel/dirt driveway!
Originally Posted by edcmat-l1
(Post 1574493321)
Headers, CAI and tune is easily worth 40 rwhp on the LS3s. Very noticable feeling. The tune itself can be worth 15-20 at the wheels. The LS3s are a little different tuning wise, so make sure your tuner has plenty of LS3 experience.
Originally Posted by Boomer111
(Post 1574517730)
I got 48 rwhp with those mods/tune.:iagree:
If these LS3's really do gain 40+hp with headers and a tune, that's fantastic! :cool: :yesnod: |
Originally Posted by JRHAWK9
(Post 1574519070)
What were your before/after numbers, out of curiosity?? I'm kind of leery of accepting that much of a gain as normal, as any dyno operator can "tweak" your numbers a bit so that the customer is happy with the overall "gain" when everything is said and done. Would be nice to see some trap speeds from before the headers/tune and after. If you're actually gaining almost 50hp, one would expect an increase of ~5mph in trap speed, correct?
I had a mail order tune done and was not impressed felt no different than stock.:(
Originally Posted by davekopell
(Post 1574521054)
(Post 1574532354)
Who's tune?
(Post 1574563338)
I would rather not say who's tune it was, it cost me nearly $400.00 and i needed to have a local tuner fix the issues. The entire cost when all was said and done nearly $900.00. Needless to say it left a bad taste in my mouth:(
