2.5" Rams Horn + alternator
Hi
I am looking at the 2.5" Rams Horn exhaust manifolds available at places such as Speedway http://images.speedwaymotors.com/RS/.../9300327_T.jpg http://www.speedwaymotors.com/25-Inc...olds,9133.html My Vette is a 71 that has 2" Rams Horns with a different alternator attachment (end bolts on manifold) compared to these ones that have 2 facing bolt holes. Would i just need an alternator bracket from a 63 vette that attaches to the 2 manifold bolt holes to use them ? Does anyone have experience with these ? |
I would think you can just cut off the extensions and grind smooth.
The front head mount for the alt is a good mount. |
If you use those manifolds the stock front 2.5" pipes froma 63-5 SBC C2 will fit like a glove (only verified on Vettes with Muncie and Tremec manual transmissions, TH400 your on your own.)
Thanks for the comments.
