Draining/Flushing LT1 Coolant System
Hi,
I just finished replacing the WP on my 92 LT1 and want to flush the entire coolant system. Where are the block drain plugs/knock sensors located? Are they accessible from the top or the bottom of the car? Will they brake loose easily or is their a chance of breaking them off in the block? Thanks, 92WhiteVetteGuy :cheers::cheers::cheers: |
well you do have most of it out already if you replaced the W/p.
Did you install a drain in the weep hole. |
Knock sensors are on both sides in the block.
On my 92 they have shields over them so the sensors aren't visible until you remove the shields. |
You'll need to get under the car to remove the knock sensors, they're just above the oil pan on the block.
Originally Posted by tblt44
(Post 1575015426)
Did you install a drain in the weep hole. :cheers::cheers::cheers: |
I will take picks when I do mine,I will be working on it all week.
I think I'm gona wait till I get all new hoses before putting it back together. |
Next time, remove your thermostat, open the radiator pitcock, then use a 6.0 hp (or higher) ShopVac with reverse thrust/blower capability and BLOW the air out using forced air.
You don't have to remove the knock sensors this way, plus it evacuates the entire system, heater core and all. :thumbs: |
Originally Posted by onedef92
(Post 1575025765)
Originally Posted by boonie c4
(Post 1575026157)
Been there done that + i agree %100
Hate to say this but the $5.00 flush kit they sell at parts stores dont work to bad. just tee the fitting in hook up water remove lower hose and let it run. not professional but removes a lot of crap
Originally Posted by hooked073
(Post 1575027750)
(Post 1575027750)
No worries. I often use the flush kits to break up mineral deposits and other contaminants, PLUS the ShopVac technique. Still don't have to remove the knock sensors, just the thermostat. I always like to inspect/test thermostats when I do cooling system flush-n-fills anyhow. Annual maintenance item. |
(Post 1575025765)
where do u blow from. the t stat housing? rad cap? take t stat out and bolt housing back together?
Originally Posted by renhod
(Post 1598277993)
Shop vac worked great. Sucked out all my coolant. Only 55,000 miles. Coolant was nice and clear orange. New water pump and wires. New plugs also. Real PIA job Wires go behind the air pump. Took the inner fender skirt off gave good visibility. Old wire were decent probably did not need new ones. I can see why the dealer wanted $$$$ to do the job.
Originally Posted by LUDS 96
(Post 1599456383)
I know this is an old thread but I would like to try the shop vac blowing system. I see take out the thermostat. Do you blow where the thermostat sits? Thank you very much, Dan
I have found a description on the net but I never trust them. It said to take out the thermostat but bolt it back up with the gasket. Remove both radiator hoses. Blow from the top and everything comes out the bottom hose. Can an expert please confirm this is correct? Thanks again, Dan
