C5 Insulation "Mad-Mat" Kit... $185
C5 Pre-Cut Mad-Mat Full Insulation Kit http://i651.photobucket.com/albums/u...s/Madvette.jpg CLICK HERE TO ORDER!!! $185 plus $20 shipping in the continental USA. DOWNLOAD THE INSTRUCTIONS HERE!!! The MadVette C5 Pre-cut Mad-Mat Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors. Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors, which allow road noise to be present in your front cabin. Our kit gives you everything you need to COMPLETELY insulate your C5 Corvette. Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs, for those who are weight conscious, it rejects 97% of the radiant heat, and has a manufacturer's rating of 19db of sound and road noise reduction!!! (please see the notes below on this... ) It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & all pieces are clearly labeled for your convenience. It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!! Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C5!!! Each kit comes with the following pieces:
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C5 kit is the perfect addition to your C5, and is recommended for every Corvette owner as the #1 modification for their Corvette!!! Your Corvette will be cooler in the summer, alot less noisy, and you will regain use of your center console once again. :) Alot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates. Some have emailed and asked, so here is a picture of the material, as well as some specs on the material itself: It has 5 layers, and though it is rated at a 19db drop in noise, my customers have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it: Characteristics | Value | Regulation Cell Structure: Closed Nominal Thickness: 5 mm (+ or - 0.5mm) Steam Permeability: 0.033 gr/m2hkPa ASTM E-96 Noise Insulation: 19dBA IRAM 4063 at 50hz. Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84 Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84 INSULATION LAYERS Aluminum Foil polyethylene backing closed-cell Polyethylene foam polyethylene backing Aluminum Foil Pictures of the kit installed in a C5 vert are below. :cheers: http://i651.photobucket.com/albums/u...SC07251med.jpg http://i651.photobucket.com/albums/u...SC07156med.jpg http://i651.photobucket.com/albums/u...SC07155med.jpg http://i651.photobucket.com/albums/u...SC07154med.jpg http://i651.photobucket.com/albums/u...SC07153med.jpg http://i651.photobucket.com/albums/u...SC07152med.jpg http://i651.photobucket.com/albums/u...SC07151med.jpg http://i651.photobucket.com/albums/u...DSC07148ed.jpg http://i651.photobucket.com/albums/u...SC07146med.jpg http://i651.photobucket.com/albums/u...SC07144med.jpg http://i651.photobucket.com/albums/u...SC07145med.jpg http://i651.photobucket.com/albums/u...SC07143med.jpg http://i651.photobucket.com/albums/u...SC07138med.jpg http://i651.photobucket.com/albums/u...SC07141med.jpg http://i651.photobucket.com/albums/u...SC07136med.jpg http://i651.photobucket.com/albums/u...SC07135med.jpg http://i651.photobucket.com/albums/u...SC07134med.jpg http://i651.photobucket.com/albums/u...SC07133med.jpg |
Good morning bump...:thumbs:
What's the different between this and the stuff that other forum members have bought from Home Depot?
Originally Posted by Dale002
(Post 1575341273)
There are several differences in the material itself, most inside, and mostly technical specs, that result in better effective results from our material. While I don't have those specs in front of me from the material at Home Depot or Lowes, their material was one of the different materials we tested before deciding on our choice of material. We believe, and many members have confirmed this, that our material is better in many ways to any other material on the market, and does a great job in knocking down both noise, and heat in the Corvette, and with the instructions, and clearly labeled and pre-cut pieces, it makes our kit the "most valuable" kit on the market to date. We are available to walk you through the install as well, should you need our assistance, and we don't just want to sell you a insulation kit, but instead be satisfied with our product and the results, and help you make a better, more informed decision. :cheers: |
:eek: Looks like a nice product ... wish GM offered this (standard feature, or an option). Would love to get this done to my car! :yesnod:
As far as the product itself, it looks like a honeycomb (or variant) ... which is NOT entry level stuff. Home Depot & Lowe's predominantly sells low cost product(s), which serve a basic purpose ... not necessarily a specific purpose. HD & Lowe's will most often select a product with the most profit margin ... versus the best product for the job. As an example ... Moen faucets are known to be WASHERLESS ... however ... in order to sell at a *low price* ... Home Depot mandated Moen make their product CHEAPER. The only way to do this was to remove the washerless technology, and install washers in its place. So while you can buy a Moen faucet for less money at HD ... it is not necessarily the same faucet as you can get elsewhere. Disclosure: I am not affiliation with this posted product or seller. :thumbs: |
Thanks Guys.
I put this kit in my vert earlier this summer. Easy install since its pre-cut. While the carpet & passenger seat was still out I went for a drive. With a thermal IR gun, the exposed surface temp of the torque tunnel was 160 degrees idling in the garage, and 92 degrees where there was insulation.
Regarding the sound level redunction, I now hear my Borla Stingers out "behind" the car rather than "underneath" if that makes sense. It knocks down the road noise as well. Well worth it! Todd |
Originally Posted by toddk
(Post 1575344250)
Regarding the sound level redunction, I now hear my Borla Stingers out "behind" the car rather than "underneath" if that makes sense. It knocks down the road noise as well. Well worth it! Todd Todd, You really had a nice reduction in temps around your torque tunnel. Thanks for the comments.....:thumbs: Tim |
I'd like to hear an audio file of a car with this kit installed and before the kit installed for road noise.
Originally Posted by wilkinru
(Post 1575345345)
Tim :cheers: |
Good evening bump.....:thumbs:
I have this on my car as well. It's amazing. I put it on when I put on my long tubes, off road X pipe, and did the bypass mod to my factory TI system. Its actually quieter now then before I did all the exhaust mods. Great product!!
Originally Posted by mattressbouncer
(Post 1575356765)
Brandon, thanks for the glowing review! :thumbs: :flag: Tim :cheers: |
Originally Posted by SDLong329
(Post 1575343337)
As far as the product itself, it looks like a honeycomb (or variant) ... which is NOT entry level stuff. Home Depot & Lowe's predominantly sells low cost product(s), which serve a basic purpose ... not necessarily a specific purpose. HD & Lowe's will most often select a product with the most profit margin ... versus the best product for the job. As an example ... Moen faucets are known to be WASHERLESS ... however ... in order to sell at a *low price* ... Home Depot mandated Moen make their product CHEAPER. The only way to do this was to remove the washerless technology, and install washers in its place. So while you can buy a Moen faucet for less money at HD ... it is not necessarily the same faucet as you can get elsewhere. Disclosure: I am not affiliation with this posted product or seller. :thumbs: Thanks, you are correct! Since GM doesn't offer something like this as an option gives us the opportunity to provide a great after market product. :thumbs: Tim :cheers: |
(Post 1575344056)
Thanks Guys.
:thumbs: |
Good morning bump....:thumbs:
Tim |
The pre cut material sure sounds nice. Some years ago I used the Lowes stuff and it can be interesting job to say the least.
Originally Posted by T VETTE
(Post 1575379784)
Can't get much easier than using our pre-cut pieces. Well, maybe if you have a couple of friends do the install for you. :thumbs: The insulation rolls from the Lowes, Home Depot, etc., don't compare with the material we use for our kits. Tim |
