Which carburetor for a 305?
I currently have a 650 cfm Holley on my 305 and am told that it is too much. I'm told I should go with a 500 or 550 cfm. Any opinions?
Originally Posted by Stooney
(Post 1575354175)
It is not really so much the size of a carb, but the tuners ability to make what ever he has work. If it's a Vacuum Sec. carb you should be fine. Smaller carbs tend to run better at lower rpm though. |
I have run the 650 on several 305s and was very pleased with the results. Even had the marine version on a boat with exceptional performance.
570 street avenger.
Originally Posted by wiseman79
(Post 1575360701)
570 street avenger.
I had the 670 on my stock 270hp 350 and performed great, had the 870 version on a 406.
gkull is correct: Properly set up, pretty much any size carb can be made to run fine. But a "correctly" sized carb is easier to set up right, and is more forgiving of tuning errors. Assuming your 650 is a vacuum secondary carb, there is nothing wrong with running that on a 305 - it should run just fine. I doubt you'll see any positive change dropping down to a smaller carb, since the vacuum secondaries on your 650 will never open up to the full 650 capacity of the carb. If you are having problems with drivability, you'd be better off correctly tuning and setting up that carb than switching over to another carb, which will also need to be set up and tuned correctly...
Lars |
Thank you all. I've been running rich so I went ahead and put smaller jets in the carb (3 steps down) and we'll see how this does for now. I'll have somebody who knows what they're doing take a good look at it tuning wise.
