Help ID this camshaft
http://i3.photobucket.com/albums/y57...2/IMG_0021.jpg
Solid lifter from a small block and it's cast iron. These are the only marks on it except an "AX3' cast between the middle lobes. It was in my '69 350 when I bought it. I yanked it out because I didn't know the correct valve lash. The local Chevy dealership and speed shop struck out on who made it and what the specs are. Can you help me identify this stick? |
The 7141 is the end of the part # but I could not find anything on it. I would look up those #'s in the vete finders book. I did find this link to cam #'s but Yours is not on there. There is a 7140 but its for a 12:1 motor. Here is the link.:cheers:
http://www.nastyz28.com/sbchevy/sbccams.php |
according to this link you have chevy part number 3927140, try measuring the lopes and compare to cam specs.
www.camaros.net/forums/showthread.php?p=992289 |
and the "-140" cam was casting #3927141 - the "7141" will appear raised on the rough core portion of the cam. If you don't see a raised "7141" on it, I'd question its originality. |
Hello the 7141 Gm cam was an offroad camaro cam used in the late 60s early seventys. . with lift 485 lift and 324 duration on intake valve and exhaust both.i used to run this cam in a 327-365 motor. Sliggish at idol speeds and low rpms but top end and high rpms it was a bad ass cam.
