TPMS tool
I am about to get a TPMS tool to be able to use the tire pressuring system on both my street rims as well as my track rims.
When looking through the options I found one for $149 that seems to do what I want. Has any one tried it? Does it get the job done? http://www.westcoastcorvette.com/p-2...and-sport.aspx PeO. |
http://www.corvetteguys.com/corvette-tpms-tool.html
This is the one I got, it works great. Plus they sell it in a kit with four TPMS also. You get the four TPMS and the tool for $179 |
Originally Posted by PeOR
(Post 1575520997)
When looking through the options I found one for $149 that seems to do what I want. Has any one tried it? Does it get the job done? http://www.westcoastcorvette.com/p-2...and-sport.aspx PeO. Like d.medic says, check that link in his post and you'll see the exact same tool for $109. That VT10 is a good but very simple tool. Personally, I think cheaper is better - especially when it's a more capable tool (does a little bit of diagnostics and can be upgraded), like this TIPS Tool for $71.57!!!: http://www.ntxtools.com/network-tool...-TIPS003A.html BTW, I think you have a 2005. When was it built? (month/year of build is on a sticker on the driver's door) If you have a very early 2005 (built in about Sept 2004 or earlier) with original tire pressure sensors, those early sensors didn't need a tool. If you're getting a second set of wheels/tires/sensors then you'll need a tool to program them. Bob :flag: |
I agree with Bob and pretty sure the Tips003A tool has two way communication with the sensor, rather than just transmitting a reset signal like some of the inexpensive job's. I've been doing the track set up switch like you're talking about for a couple year's now, and find it nice to have the better communicating tool, so I can check if the sensor's are functioning on the wheel set just sitting in the basement.
Originally Posted by BEZ06
(Post 1575521581)
I don't know why they're selling that ATEQ VT10 for so much.
I got a VT10 as part of a sensor package from corvetteguys when they were having a very good sale. It does what I need so I'm happy with it.
Awesome
This forum is AWESOME. Thx for great help. I will go for the OTC-TIPS003A
My car is built Oct 2004, so it might be that my existing sensors are too old. We will see. Do you have any recommendation of tires sensors as well? PeO. |
How can I disagree with Bob when it comes to TPMS??????? I also got the TIPS tool at his suggestion and am very happy with it.:thumbs:
I got the one that Tire Rack sells for $105 and it works great.
(Post 1575522402)
My car is built Oct 2004, so it might be that my existing sensors are too old. We will see. Do you have any recommendation of tires sensors as well? PeO. I have only used OE sensors. The OE sensors for the 2005-2009 C6 are GM Part# 25758220. Forum vendor Gene Culley ( www.gmpartshouse.com ) or Parts Taxi ( www.partstaxi.com ) has them for around $250 for a set of 4. Here's a quote from Gene's site: C6 Tire Pressure Sensors 2010 + 15268606 – Tire pressure sensor - $45.45 each 15234846 – Tire pressure sensor nut - $3.89 each Total set of 4 nuts and 4 sensors $216.70 shipped. Note: The sensor comes with the washer and valve stem cap. Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts. 2005 – 2009 25758220 – Tire pressure sensor – $57.78 each 15234846 – Tire pressure sensor nut – $3.89 each Total set of 4 nuts and 4 sensors $270.85 shipped. Note: The sensor comes with the washer and valve stem cap. Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts. You can see you'll also need to order 4 retaining nuts. Take a look on eBay (just search for the part#) and you can find some used ones for a lot cheaper (actually I just looked and saw 4 brand new ones for $200 with free shipping - but you'll still need the retaining nuts). Anybody reading the thread that has a 2010 or newer can see that Chebie changed to a different sensor in 2010. The older sensors won't work in a 2010+, and the newer sensors won't work in the 2005-2009 C6. Bob :flag: |
Odbii
I see that a tool on Tirerack for $125 has an ODBII port and you dont have to actually do the "walk around the car and initiate the sensors".
http://www.tirerack.com/accessories/detail.jsp?ID=163 Is that a preferred way to shift sensors? EDIT - I know that my current sensor mapping is messed up, since I intentionally tried to match up a friends tires, so that could always be with no sensors connected (and then not have a problem coming to track with one or a few sensors still not having let go). This would mean I cannot read out the original sensor id's unless I boot them with the TIPS003 tools. So, it will probably be the TIPS one anyway. And Bob - I owe you a case of beer. PeO. |
(Post 1575525264)
http://www.tirerack.com/accessories/detail.jsp?ID=163 ..... I don't know anything about that tool, but I think it's this one: http://www.ateq-tpmsreset.com/TPMS_tool_comingsoon.html In that link it shows that it only works on Asian cars. I don't think it will work with any cars except those Asian vehicles in the thread above. You won't go wrong with the TIPS tool!!:thumbs: Below is a video where I'm using a TIPS tool on my C6 sensors. Bob :flag: |
Bob, don't you have any pictures of the TIPS tool completely disassembled so we can see inside????:rofl::rofl:
And I can't see how the programming of the system could be done without walking around the car because the car would have no way of knowing which sensor was in which location. |
Just to add a bit to this conversation ... think someone pointed out earlier we sell the VT10 - that's correct. That's also what Tire Rack sold at the time we started carrying them, as I understand it.
I can also send you a code for 6% off your order if you PM me. :thumbs: We also offer free shipping on everything including wheels & tires too every day. If you're looking for sensors, the sensors we carry are Oro-Tek - they're OE reproductions. We have the C5 & C6 thru '09. Will have to talk to them about getting the '10 style sensors. Let me know if I can be of assistance. |
Also, our VT10 is priced at $109.99 with free shipping. Unfortunately the sensors are priced much more steeply - and for the cost you might just want to go OEM. (unfortunately the gentleman above who got the set of 4 and the VT10 got them a while ago when we were able to offer the kits quite cheaply, which is no longer the case). The sensors are $179.99 (free shipping) for 4.
Interesting
Originally Posted by CorvetteGuysGal
(Post 1575532078)
I can also send you a code for 6% off your order if you PM me. :thumbs: We also offer free shipping on everything including wheels & tires too every day. If you're looking for sensors, the sensors we carry are Oro-Tek - they're OE reproductions. We have the C5 & C6 thru '09. Will have to talk to them about getting the '10 style sensors. Let me know if I can be of assistance. PeO. |
(Post 1575532149)
Sounds very interesting. You don't happen to have the tire pressure nuts, do you? And d.medic was talking about a kit with tool and sensors from you.. but I cannot find the one with the sensors in a kit?
PeO. Their sensors come with everything needed to install including the nuts. |
The OBD connector tool looks quite intersting, but seem's like a pain to set up. Quite honestly it only take a minute or so to walk around the car with a conventional tool. Also, as mentioned, it's a nice feature with a better conventional tool to check for a bad sensor with the wheel set being nowhere near the car, as can save you the trouble of mounting it, then getting frustrated trying to track it down later. Also can scan the sensor's of a parked car just sitting there.
(Post 1575532149)
PeO. |
It is an important point that this set of sensors comes with the gasket and the nut....the GM ones are sold as three separate items and can add to the price quite a bit.:thumbs:
