Brake Rotor Hub Covers?
Has anyone used brake rotor hub covers to hide the rusting on the rotors? Any feedback would be appreciated... Do they fit well, do they look good???
I'm very pleased with them.
I had them powdercoated to match my paint by http://thepowdercoater.com/ |
Hubs
I think they just cover the hub not the rotors. But there is a car care item to wipe on to take of rust after washing if you don't want to drive it off. Its sold by Groit. Hope this helps.
They just hide the rust on the hub, water can still drain down onto the wheel barrel and causes stains from the rust. And they don't do anything for rust in the outer vent area. It's better than nothing though.
I think a better solution is to use a zinc coating on the hub - one of the members here did an excellent DIY a while ago, I think that's worth doing and may actually be cheaper. |
They look good Mars, however, I wish they were wider and came out to the edge of the cut rotor surface. That would look like a 2 piece rotor, which I'm on the fence about. I love the look of the 2 piece, but I'm not fond of the price...
I don't have them on my car but I have seen them on a C5 and a couple of C6s and I do like the look. My hubs have not rusted yet and still look pretty good.
Originally Posted by spinalator
(Post 1575772299)
Now that I'm looking at them I might try to polish the uncovered part of the rotor. That may look better. |
My car wash "guy" took it upon himself to use muriatic acid on the rotors to get rid of the road grime. They looked great for about an hour and then they rusted. They actually looked better with the road grime on them... I really like the Baer eradispeed 2 piece rotors but I really don't want to dump 1200 bucks on them.
I painted mine with high temp engine enamel.
http://i139.photobucket.com/albums/q...swheels008.jpg :cheers: |
The best thing to do is to either have them zinc plated or powder-coated. Another option would be to paint them with high-heat black engine paint after removing all the rust, brake dust and dirt. I have seen all three and they all look very good. Just offering some options here. :thumbs:
Those look great Vet4les, how involved was the "project"? Did you have to remove the rotors to paint them? How did you mask the cut surface so as not to get paint on them?
5 Attachment(s)
Just had mine cleaned and painted with high temp paint under warranty. They also cleaned and painted the edge of the rotors.
a black permanent marker will work just fine also. I did mine all the way to the wear area on the rotor. Took about 5 minutes a wheel. Dont worry about getting it on the rotor surface, first time you hit the brakes, its gone. I did have to use 2 markers though.
not to go OT, but i must be doing something wrong - 3 years and 14K miles, and minimal rust -
http://i68.photobucket.com/albums/i1...g?t=1288429230 not sure why - about the only thing i can think of is i do use a wheel cleaner, and besides the wheels and barrels, i do spray the hell out of my rotor hubs and calipers - ??? - there just might be something in the cleaner that's leaving a thin film of something... - ??? |
Originally Posted by firecop90conv
(Post 1575773912)
Originally Posted by Joe C
(Post 1575774462)
Originally Posted by MARSC6
(Post 1575775337)
My 06 rotors still have no rust. Never used any special cleaner.
(Post 1575773912)
Do they make hub these covers for the Z06?
U.M. |
