1991 TPI to Carb Swap???
I recently acquired a 1991 Corvette, with TPi in a trade. The condition of the wiring under the hood is a nightmare because the car sat for years and rats had a feast on it. I'm considering converting the TPI to a carburetor, but I,m finding that hood clearance is going to be an issue. Does anyone have suggestions as to what intake/carb combo I should use, or any other tips and factors I should consider before I start? I'd appreciate any photo references from those of you who may have made this conversion.
UPDATE!!!!...Ok after some patching to the wiring, adding a new fuel pump, plugs and wires I actually got the car to start and run!! However when i drove it, the car appeared to be running on only about 4 or 5 cylinders. Soon after that the car wouldn't start. I checked the pressure at the rail by turning the key to the on position to engage the pump. The gauge immediately jumped to 50 psi but fell back to 0 within a couple of seconds. Does anyone have any clues what might be causing this? I know I'm getting spark because I can spray injector cleaner directly into the throttle and the car starts but quits as soon as the cleaner burns off. |
When I carbed my 84, I used a low rise, dual plane Weiand manifold and a Holley vacuum 750 cfm carb and a dropped base 14" air cleaner. Tight hood clearance. Sorry no pics.
Originally Posted by 383vett
(Post 1576256380)
Car ran well. Main problem was fuel perculation after shutoff. Had to put ducts in the hood to vent air. Switched to a SuperRam later.
http://i539.photobucket.com/albums/f...o/10-22-08.jpg |
Originally Posted by marlonb601
(Post 1576256313)
http://i171.photobucket.com/albums/u.../carbonTPI.jpg Or see http://forums.corvetteforum.com/c4-t...tock-hood.html http://forums.corvetteforum.com/1565824290-post28.html http://forums.corvetteforum.com/1575279731-post2.html http://forums.corvetteforum.com/1562777550-post26.html http://forums.corvetteforum.com/1575137446-post33.html http://s31.photobucket.com/albums/c3...Picture344.jpg |
Why not try one of our vendors here for a good used engine wiring loom? I would think that would be easier than switching to a carb. Also if you try to sell it, a carb my limit who wants to buy the car. JMO
(Post 1576256313)
UPDATE!!!!...Ok after some patching to the wiring, adding a new fuel pump, plugs and wires I actually got the car to start and run!! However when i drove it, the car appeared to be running on only about 4 or 5 cylinders. Soon after that the car wouldn't start. I checked the pressure at the rail by turning the key to the on position to engage the pump. The gauge immediately jumped to 50 psi but fell back to 0 within a couple of seconds. Does anyone have any clues what might be causing this? I know I'm getting spark because I can spray injector cleaner directly into the throttle and the car starts but quits as soon as the cleaner burns off. That sounds like a bad fuel pressure regulator. |
(Post 1576257291)
http://i539.photobucket.com/albums/f...o/10-22-08.jpg Your car is a work of art...but it pains me to look at it because it reminds me of how far I have to go. Thanks again for your input. |
(Post 1576270829)
Thanks for that info. I appreciate you bringing that factor to my attention.
