C6 Oil Pressure SENSOR GONE BAD! 80 PSI CONSTANTLY!
OK SO I GOT THE DREADED 80 PSI reading on my car and it merely sticks there when turned off and back on. I know that this most likely indicates a faulty oil pressure sensor. I checked the oil level an it is fine. I did the search on this forum and I got the C5 DIY. I was was wondering if anyone knew a step by step for a C6???
Would greatly appreciate it. Otherwise I have to drop the car off to the dealership... And I really hate being without my car. |
Also does this problem EVER just go away. Or is it most definitely a replace deal?
Gremlins.
I just had a faulty sensor replaced. However, mine did not read 80 psi, mine said "faulty sensor." Discount tire put one on for something like $55 installed (not positive on price, but it was reasonable).
I've heard that if you reprogram the sensor sometimes it will start working again, that's worth a try. A good tire store or your Chevy dealer should be able to reprogram the bad sensor. |
No No. THIS IS AN OIL PRESSURE not TIRE PRESSURE Sensor!
Otherwise known as the OIL PRESSURE Sending Unit. Which apparently sits behind the intake manifold.
I have been doing a lot of reading here. Is the procedure the same as that of a C5??? I am curious if the C6 is easier to reach? ANYONE?
Check out the postings in the C6 Tech forum. Recent discussion on this very issue. Sounds like a deep socket and a little agility is all that is needed but then ............
I remember it being a difficult process on C5. Some advised replacing with the remote unit set up. Does that not also apply to the C6?
I don't think agility has anything to do with replacing this monster.
You have two choices: 1) Remove the intake manifold and gain access to the top rear of the engine 2) Dill or cut a hole in the plastic cowling under the wipers as show here http://forums.corvetteforum.com/1558850078-post7.html With my supercharger sitting on top of my engine, I can guarantee you that I am going to use #2 if my sensor takes a crap. Elmer |
Yes my third option is warranty. If this is a really big problem then I would maybe submit to dealership.
part is about $40; I've done dozens of C5's
It's common across the entire GM LSx vehicle line |
Originally Posted by Ahmer
(Post 1576313387)
Try the dealer 1st ?
Ok. I plan on doing the Sensor, LSD fluid changeout and possibly the service 2 maintenace.
Number 2 is my choice if I ever have a problem. :thumbs:
I'd do number 1, taking the intake manifold off is a very quick & easy job.
oil pressure sensor
Did you ever get this done on your car? My pressure gauge is pegged and I have to change my sensor too. The only detailed drawings I'm finding are for the C5. I do not want to start cutting on my car to find this little part without a little more help.
Thanks!
(Post 1576320208)
Originally Posted by bocallaghan
(Post 1576854815)
Thanks! |
