LS2 FAST 102 install (with pics)
7 Attachment(s)
I just got it today, thanks Seth (Hinson). :thumbs:
I'll be doing it Saturday- It's pretty simple but I'll take a few pics of removal and replacement if it would help inspire a few guys to do this who would normally pass on doing it themselves. I am considering doing the port work now OR just do it when I swap the heads in a few months, not sure. Each runner could use some attention though since you can see the actual runner is a bit smaller than the base of the maifold. I would save port matching the base until I decide on my heads, TFS 225's or 235's depending on what size shortblock I go with... so many options. Now I gotta come up with $150 for my ECS tune! Damn, it never ends- Attachment 48153316 Attachment 48153317 Below, you will see the smaller runner through the base port. Attachment 48153318 Attachment 48153319 Attachment 48153320 Attachment 48153321 My little one as curious as ever! Attachment 48153322 Have a good night fellas- |
Just a few words on that Combo
Nice Pics. One thing to keep in mind if you use the TFS 225 in conjunction with the 102 you may have to clearance the underside as there are places
where it will not seat properly at least that was my case and the manifold had leaks and had to be sent back. I ported mine and eventually picked up 5 to 7 RW over the PORTED 92. Good luck with it and please keep us posted. |
Originally Posted by LSCHLEM
(Post 1576636935)
Originally Posted by ITS STOCK
(Post 1576638026)
When you say clearance do you mean shave down some of the ribs that are on the bottom of the manifold? I'm doing TFS 225's soon and would like to know this while I'm doing the install rather than after when theres a problem. :thumbs:
I did back in the Summer. As soon as I got my new replacement from Hinson who stepped right up for me and got Comp to replace it. I was worried for a bit they would try to assert improper installation but they were good about that. I clearanced the Ribs with just a small half moon indentation at the suspect clearance spots. I dont know if the 235 TFS would be better. but I do know that the 102 has smaller runners and they are longer. I do however know that it should be ported otherwise the PORTED92 would have prevailed over the stock 102. There is much controversy about these manifolds but you don't see members throwing away their PORTED 92's and getting a 102 right away. Its close and the 102 best be PORTED. |
I'll get the 102 ported when I do the TFS 225's for now I'm gonna throw it on the 243's out of the box. Do you have the link to the thread with those pictures by any chance.
(Post 1576636935)
Originally Posted by LEAVINU
(Post 1576639335)
Any other gains other than peak? Midrange? Decent tq gains?
Well, for me, going from a stock LS2 intake to a FAST 102 will be pretty sweet, ported (for now) or not.
I remember when Spin ported my FAST 92 and I replaced it over my ported LS2 and I was very impressed, though I already had H/C/Bolt ons. |
Couple of tips for a 92...but not positive they work on a 102.
On a 92 you don't have to unhook the fuel line. Just flip the rail back on the windshield and out of the way. If the ls2 fuel rail & injectors fits the 102 that should be the same. On the 92 we have to use washers to hold down the fuel rail as the holes don't line up to the tabs. I think that changed on the 102 and the ls2 fuel rail fits without washers? 92's use ls1 injector 0-rings which are available in stock at Advance Auto usually. Don't know what the 102's use, but you might want to search for that. The 4 bolts in the back stay in the manifold as you pull it forward. Use about 1" of vacuum line, cut, to hold them up out of the way when sliding the manifold forward. I do it by hand but I've done it a bunch of times. You'll see what I mean when you do it. Unhook the brake booster line from the booster, then when you pull the manifold forward, pull the line with the manifold, feeding it from the back. You won't be able to unhook it while the manifold is in place. Be careful of the oil pressure sender in the back that the brake booster line snakes around. They are expensive if you break it so don't pull on the line too hard! Hope that helps. Keep us posted. |
Originally Posted by Joe_G
(Post 1576640646)
On a 92 you don't have to unhook the fuel line. Just flip the rail back on the windshield and out of the way. If the ls2 fuel rail & injectors fits the 102 that should be the same. On the 92 we have to use washers to hold down the fuel rail as the holes don't line up to the tabs. I think that changed on the 102 and the ls2 fuel rail fits without washers? 92's use ls1 injector 0-rings which are available in stock at Advance Auto usually. Don't know what the 102's use, but you might want to search for that. The 4 bolts in the back stay in the manifold as you pull it forward. Use about 1" of vacuum line, cut, to hold them up out of the way when sliding the manifold forward. I do it by hand but I've done it a bunch of times. You'll see what I mean when you do it. Unhook the brake booster line from the booster, then when you pull the manifold forward, pull the line with the manifold, feeding it from the back. You won't be able to unhook it while the manifold is in place. Be careful of the oil pressure sender in the back that the brake booster line snakes around. They are expensive if you break it so don't pull on the line too hard! Hope that helps. Keep us posted. This one came with O-rings but as far as the fuel rail mounting and any other issues, I'll be sure to bring them up. :thumbs: |
Great info Joe!
Jason, when you put the top back on be sure to look all the way around it before bolting it together with the base, when it is put together properly it will basically snap together as it is a pretty snug fit. I think some have tried to bolt it back together and it wasn't "snapped" in all the way around which would cause some issues. Definitely use the supplied o-rings for the injectors also. Looking forward to your pic's and write-up while you are doing the install. :cheers: John |
Originally Posted by Neumonic2002
(Post 1576642064)
Great info Joe!
Originally Posted by JayplaySS2
(Post 1576641275)
You're 100% correct Joe, I did the exact same process and ran into the same issues with my Spin FAST 92 on my 1st C6. Thank you buddy-
4 Attachment(s)
(Post 1576639263)
1 & 2. SHOWS THE TROUBLE SPOTS AS INDICATED ON THE TIPS OF THE CALIPRE 3 SHOWS THE 92 NO PROBLEMO 4. SHOWS THE SMALL HALF MOON CLEARANCED AND READY TO GO. |
(Post 1576640572)
The gains were pretty much the same the entire range not much but nonetheless noticeable. 5-7 .
14 Attachment(s)
My laptop just froze after I had thos 90% complete DAMN IT.
This is the 2nd time around- Begining- Started @ 10:30 am and had it complete and running at 1:30 pm. This even included a quick trip to parts store for RTV and a coffee run for my wife. This is a breeze guys- Disconnect the battery- Attachment 48153261 I removed the CAI, tb, coils and even the fuel rail with a fuel line disconnect tool, very easy. I remove alot to have plenty of room, Attachment 48153262 My cool ass wife helping :) Attachment 48153263 Attachment 48153264 After removing the items, remove the 10 8mm intake bolts- On the last 2 rear bolts zip tie them together so they stay in the intake, zip tie them as tight as you can. Attachment 48153265 Attachment 48153266 Attachment 48153267 Once they are secure and the remaining bolts are removed, shift the rear of the intake to the pass side to snake the booster hose by the oil sending unti. Attachment 48153268 Oil sending unit, don't break it. Attachment 48153269 Look at those botls, right where I left them :) Attachment 48153270 The weight... I weighed them BARE- LS2 (bad pic) 6lbs- Attachment 48153271 FAST 102 (bad pic) 11lbs Attachment 48153272 Attachment 48153273 Attachment 48153274 More on the next post- |
(Post 1576648815)
IIRC, you had some issues with the port job on your 92 right?
and I thought the 102 would deliver all kinds of power over the controversial 92 . as it turned 5-7 RW across the band was all to be had. In my humble opinion I believe a PORTED 92 will outperform a STOCK 102 but not a PORTED one. I thought I posted the dynograph back then and many months later I still do not see any data Points to make a grand conclusion about this. Those who have 92's are keeping them and those who are going for the fast are going with the 102 for obvious reasons. |
Hang in there Jay. You are almost there. Leon
9 Attachment(s)
I cleaned the heads as well as I cared :)
Here you see all 10 button head screws FAST supplies to clear the FAST floor. Attachment 48153252 You need to drill 3/8 hole where the map sensor goes (LS2). Be sure to clean the intake OR remove the shell to drill it. Attachment 48153253 Plug the extra vacum port on the rear next to the brake booster line. I used a screw with RTV- Attachment 48153254 Remove the LS2 intake gaskets and transfer them to the FAST. Attachment 48153255 Install all 8 0 rings (use motor oil as lubricant) and install the rail with a little locktite on the bolts. Don't cross thread these small bolts, the fuel line has to be pulled for perfect allignmet of the bolts. Install the Map sensor with the new screw. Attachment 48153256 Zip tie the 2 rear bolts on each side to ease movement on the engine. Attachment 48153257 Set the intake on side ways, like removal and connect the booster line and snake it over to the booster. Attachment 48153258 Tighten all 10 intake bolts down in tq sequence supplied by FAST instructions, start connecting things and install tb, cai and coils. Connect fuel line and triple check everything. Reconnect the battery and start it up. Mine caught idle right away and runs just fine. Attachment 48153259 Attachment 48153260 Any questions? I flew though this post so I may go back and add forgotten items later. |
Awesome write up! One question why do you zip tie those 2 bolts on the back of the manifold?
