100 octane leaded fuel????
I've been wondering, will that work in my LS6 motor? The car doesn't have catalytic converters and is for track only.
100 octane aviation fuel is leaded/low lead and is a lot cheaper than 100 unleaded, so I was considering trying it if there is no ill effect. Thoughts? |
I fear the lead in the 100LL would do a number on your O2 sensors; I think that's one of the reasons they haven't had much success with closed loop systems in GA engines.
If that's not an issue then I see no other problems. HTH, and have a good one, Mike |
Yeah, the amount you save in gas cost you will likely spend in replacing fouled O2 sensors.
Why don't you just run 93? I do. |
Originally Posted by wallyman424
(Post 1576806967)
We've used the 100LL and it seems to work fine with used 02 sensors but if you install a new 02 sensor it will foul it out right away.
Also you won't make the extra hp with 100LL, if you are going to run race gas you're better off running the premium oxygenated racing fuels and they are over $7 per gallon. I know Sunoco has some unleaded fuels that are as high as 109 octane! For ST2 it really doesn't make sense to use race gas, since you can always find ways to make it to 8.7. |
Originally Posted by VetteDrmr
(Post 1576806766)
If that's not an issue then I see no other problems. HTH, and have a good one, Mike We changed out O2 sensors with every engine replacement (~3k race miles) but that was more due to the heat issue than contamination (and the sensors were only $150 each). That being said, running low lead or leaded WILL wipe out lambda sensors in a hurry. When we ran sensors on the NASCAR motors on the dyno during R&D, we'd go through a set of O2s every day (and those were the lab grade $750/ea sensors, one per cylinder). Like someone said, running the higher octane LL fuel won't give you anything over the 98. When we stepped from 100 down to 98, we lost 0 power. |
I'm pretty sure he meant General Aviation, not Grand-Am.
Like the others said it will wipe out the O2 sensors but even if you tuned for open loop I would not run aviation fuel. It is meant for higher altitude performance not for running on the ground.
The name 100 Low Lead came as a comparison with the previous 100/110 octane aviation fuel that had tons of lead in it. 100LL avgas still has about twice the amount of lead as was ever in automotive gas so it will wipe out oxygen sensors in a hurry. Better to use unleaded race gas since the cost of sensors will add up faster than fuel.
I wonder what NASCAR is going to do now that they are going to use fuel injection. I'm guessing that they will use an unleaded race gas so that they can use oxygen sensors and run closed loop too. |
Originally Posted by Solofast
(Post 1576816049)
Originally Posted by mgarfias
(Post 1576813849)
Have a good one, Mike |
Originally Posted by CorvetteZ51Racer
(Post 1576821384)
NASCAR has been running unleaded since the middle of 2006.
