A & A results are in!
So the install is done and the tune is done for now but needs to be completed when the weather improves. It was cold, 20 degrees at time of tune, and it is dyno tuned but not street tuned yet, will finish up in the spring.
Here's a dyno sheet before and after; http://i53.tinypic.com/1zpigie.jpg This was done on a stock 04 LS1 through stock manifold and a manual. Car does have Borla stingers mostly for sound.:thumbs: Darion :flag: |
Nice improvement from your before dyno. It'll feel like a new car :cheers:
:thumbs:
Forgot to mention the before dyno was with a Honker intake on and the stingers, no other mods.
Darion |
Very nice results!!!!!
:cheers: |
Originally Posted by Arun@CCP
(Post 1576844455)
:cheers: Your numbers would be higher if you turned the engine to a higher RPM. ;) |
Originally Posted by BLOWNBLUEZ06
(Post 1576844641)
:iagree:
Your numbers would be higher if you turned the engine to a higher RPM. ;) Amazing what an A & A system can do on a stock setup! Darion |
(Post 1576844641)
:iagree:
Originally Posted by Z06supercharged
(Post 1576845857)
Yea... crank that stock block baby up to 7K! :ack:
Darion |
Enjoy the new ponies :thumbs:
Chuck |
enjoy bro be carefull when it's cold out side cold tires and high hp bad combo.
(Post 1576845857)
Nice numbers! Congrats on the new found power!! Its all in the Tune!! |
Originally Posted by Z06wanted
(Post 1576847226)
Darion |
Originally Posted by 2003VETT
(Post 1576847263)
Ive been shifting at 6700-6800 on my stock bottom end/stock head LS1 for years:thumbs:
Nice numbers! Congrats on the new found power!! Its all in the Tune!! Darion |
nope! ECS blower cam and comp springs...
Ok, I'm working with stock heads springs and all.
Darion |
Nice numbers! You're going to love the boost.
You're probably going to need to add headers sooner or later. I blew out both cats in my car after 2-3000 miles with the stock manifolds, and the stock A&A kit. I'm adding a set this week to avoid that issue again. |
Originally Posted by winters97gt
(Post 1576849132)
200+ RWHP gain - not too shabby! :willy:
Thanks,Matt |
Sweet numbers!:rock:
