-   C4 General Discussion (https://www.corvetteforum.com/forums/c4-general-discussion-34/)
-   -   Air bag light will not go off. (https://www.corvetteforum.com/forums/c4-general-discussion/2791845-air-bag-light-will-not-go-off.html)
no1_3fan 03-08-2011 08:38 PM
The air bag light on my 1994 Corvette will not go off. When i start the car, the light flashes on, long pause, flashes on, long pause, flashes on, short pause, light stays on. I cleaned the impact sensors and the frame. Checked the codes with a paper clip and got c62 and h62 on module A. Was not able to clear them on A.7 .
Flame Red 03-09-2011 09:29 AM
The FSM is wrong to clear the code. This will help you clear the code, but not fix your underlying problem:
http://forums.corvetteforum.com/c4-t...code-35-a.html
Ok folks. Here is the trick. DO NOT GROUND K. Instead, connect K to A and follow the procedure. It worked the very first time when you use the above procedure to lead K connected to A instead of seat or any other ground.
no1_3fan 03-09-2011 05:58 PM
air bag light will not go off
On my 1994 the manual says to connect teminal 12 & 4 to enter the diagnostic mode.
no1_3fan 03-10-2011 09:40 PM
Airbag light will not go out
Any help to get my airbag light to go out would be greatly appreciated. That light is driving me crazy.
