Photos of my removed transmission pan and opened filter what you think?
Just took this out and took a few photos. Car has 119k miles and I have no idea when the last change was done if any.
What do the photos tell you? http://i973.photobucket.com/albums/a...a/DSC_0148.jpg http://i973.photobucket.com/albums/a...a/DSC_0149.jpg |
:eek: Let's us know how it works after you put the new filter and five quarts of fluid back in it.
right now i cant get the old filter seal out.... and its been a ~1 hour task thus far i have no idea what to do to get it out
Black gunk is normal for age/mileage, clutch material. Never anything you want to see but is normal wear and tear. Once most of it is in the pan and not on the clutches, slips...
Looks normal to me, nothing metallic or big chunks.
http://i38.photobucket.com/albums/e1...s/100_3532.jpg
This is what I used...a pick, it's also a bi#$h to get the new one in, it needs to go up to the lip about 2'' in so i used a handle of a screwdriver the same size of the seal and tapped it up. :thumbs: |
Originally Posted by Midnight 85
(Post 1577021706)
Just clutch sediment. Looks normal. Brass grains, burnt fluid would be a concern. Just change out and record mileage in your maintenance log-you are keeping one, right? :toetap: |
Originally Posted by SQUIRMIN VERMIN 84
(Post 1577022293)
:iagree:
What did the old fluid look/smell like? If it was pretty black and smelled burnt or sour you may not be happy with the result when you put new fluid in and drive away.
