Question about vette key.
Ok so i almost got my car started today. I wanna know if a 84 corvette has the chip thing on the key.? like this
http://i285.photobucket.com/albums/l...0/IMG00016.jpg:willy: |
nope
I believe 86 was the first year it was incorporated
Originally Posted by Donalds5
(Post 1577024036)
On the 86+s can locksmiths made duplicates or just GM dealers?
Originally Posted by Texas Stinger
(Post 1577027300)
The key number and its resistance value are listed below. Set your multi-meter to the 20k ohm setting and test your key to find out what numbert it is. 1覧覧 0.402 2覧覧 0.523 3覧覧 0.681 4覧覧-0.887 5覧覧-1.130 6覧覧-1.470 7覧覧-1.870 8覧覧-2.370 9覧覧-3.010 10覧覧3.740 11覧覧4.750 12覧覧6.040 13覧覧7.500 14覧覧9.530 15覧覧11.801 You don't have to go thru GM. Once you know your key number you can order the correct key for $2 and have your local hardware store cut your new blank key. Blank VATS keys can be purchased direct from CLK Supplies 800.848.6989 http://www.clksupplies.com/shop/inde...cPath=24_26_66 |
Originally Posted by pmihaltian
(Post 1577027553)
There are 15 possible resistance values (keys) that were used by GM.
