Originally Posted by Slvr08Z51
(Post 1577052358)
The mph killer on the C6's is the 4th-5th drop in gear ratios.. It's equivelant to shifting from 4th to 6th in a P car.. The Zr1 trans is where it's at.. I'm hoping to make the may event with a goal of 215mph..
Texas Mile
http://www.HinsonSuperCars.com/Pics/...ar/SexyAss.JPG
Good luck to everyone getting ready for the mile. We're looking forward to getting out there. We pulled our car out this weekend and did some maintenance. It made it to the dyno for some shake down runs, and we will be putting the real boost to it later this week. Cheers! :cheers: |
Originally Posted by HinsonSuperCars
(Post 1577055432)
Hinnson Supercars Texas Mile
Just because its Silver alone I'm needing to see more Pic's:thumbs:
Very nice noticed the sticker on rear, how fast have you been in that silver rocket?:eek: What tire do run in the mile? |
Originally Posted by 427silverhotrod
(Post 1577056694)
[QUOTE=427silverhotrod;1577052665]What kind of power you makingto hit 194mph?
About 625 to the wheels. |
Originally Posted by gotjuice?
(Post 1577058561)
They ran real late on Sunday and barly got on it, It ran above 210 without trying. It should set the Corvette record without any problems this time around. Hopefully it will make some good passes. I am looking forward to seeing it run.
Originally Posted by TrenAman
(Post 1577055505)
I was going to ask how safe those 345 MT tires are at very high speeds but I guess since you are taking that beast to the mile.. that answers it! Mind if I ask what tire pressure you plan to run to stay safe?
http://www.hinsonsupercars.com/Pics/...r/C6onDyno.JPG Like the guys said above, we just barely made to Goliad just in time to make a pass. We ran 210mph shutting down early. The driver was unclear where the finish line was. The next pass was the same boost level held through the traps for 214mph. Unfortunately, we did not have time to make more passes and increase the power. We're looking forward to the race and seeing all of these great cars. This trip should be more fun than our last marathon trip. :cheers: Stop by and check in with us when you can. |
Good luck Hinson, and all the other Corvette drivers.
(Post 1577062379)
We talked to the engineers at M/T, and they pretty much said they wouldn't do it. However, we decided to run them due to the short period of time at high speeds. Looks like we will be the guinea pigs. :willy: Can't say on the tire pressures as two passes is not exactly a tried and true foundation. For what it is worth, keep the pressures higher for high speed stability.
http://www.hinsonsupercars.com/Pics/...r/C6onDyno.JPG Like the guys said above, we just barely made to Goliad just in time to make a pass. We ran 210mph shutting down early. The driver was unclear where the finish line was. The next pass was the same boost level held through the traps for 214mph. Unfortunately, we did not have time to make more passes and increase the power. We're looking forward to the race and seeing all of these great cars. This trip should be more fun than our last marathon trip. :cheers: Stop by and check in with us when you can. Going to need an upgrade to the set of brass balls your running. |
Originally Posted by PowerLabs
(Post 1577033372)
I think traction is probably the biggest problem; the TT Gallardos have full time AWD and the Ford GTs have the engine/transmission right on top of the rear axle so they can both hook up better.
Originally Posted by Jasil
(Post 1577034845)
Gearing and CD are key..........look at the Vipers it's not for lack of power that they are not up with the Gallardos, GT's, and Supras.
[QUOTE=gotjuice?;1577058579]
(Post 1577052665)
About 625 to the wheels. Hinson, Pic's shows car on dyno what power are you puting down? |
(Post 1577058579)
Originally Posted by APSGTO
(Post 1577063533)
345/35-18 M/T's are skechy at the top of 4th (Z51), let alone the top of 6th! :eek:
[QUOTE=427silverhotrod;1577064828]
(Post 1577058579)
So with my 670 to the wheels I should hit mabe 197mph? If I'm lucky and get some wind 200mph? I'm not holding my breath. Hinson, Pic's shows car on dyno what power are you puting down? |
[QUOTE=gotjuice?;1577066012]
(Post 1577064828)
Torque numbers? That is what makes a difference at the mile. |
(Post 1577064828)
Maybe just turn the boost up and see if the stock piston/rods can make one pass. Boom Boom.
or just watch this car.http://www.youtube.com/watch?v=9P-jgKBSdcc |
(Post 1577067466)
I really doubt it. I don't know of any Corvette that's broken 200 without making at least 800RWHP... Has anyone done it?
I want to try with just over 700hp and zr1 gears on the stock bottom end. |
I'll be there Friday to watch my buddy run but my car isn't finished yet. I'll be there in October for sure, maybe May. Can't wait to see what my 434 LSX and F2 can do.:thumbs:
