Paddle shifter F1-mod DIY?
I've seen the F1 style paddle shift mod kits, but they seem really expensive at around $170.
Are there any DIY details for this mod? I don't want to pay "Corvette tax" for an extra paddle shift I don't need, so I'd like to modify the one already on the car. I just finished my HUD install, so I'm feeling adventurous :D |
Originally Posted by InstantArcade
(Post 1577078730)
Thanks for the great writeup!
Originally Posted by dbratten
(Post 1577078861)
Here's what I did for free -- http://web.mac.com/dbrat10/iWeb/C6-A6/index.html -- over four years ago with no problems since. :cheers:
Like the op I would like feedback on the F1 shifter for the 06-11 c6. I would like feedback not on doing the above for free, but on the actual F1 shifter available. Thanks
Jeff |
Success!
I just did this mod in about 30 mins. The hardest part was feeling for the airbag retaining clips.
I used a pin to liberate the wire from their sockets, seems like the retaining tang is part of the brown clip and not on the metal crimp connector as it usually is. I just swapped the two outer wires on the right hand paddle and it works a treat. A few things to note:
Originally Posted by lotsoffun07
(Post 1577095749)
Jeff http://www.zip-corvette.com/ProductD...GR-SR&CTitle=& I went from totally ignoring the paddles when I drive her car to using them all the time. Z// |
Originally Posted by November Soul
(Post 1577097191)
My instructions and photos captured the first ever rewiring of the paddles and can be simplified and enhanced as you note. Maybe someday I'll take the time to redo them -- but probably not. I prefer having the + act the opposite on each side as it makes one-hand control possible especially with the wheel turned or if your right hand is otherwise occupied. :cheers: |
sweet mod, on the wheel with audio controls you dont have to remove the horn ring, just the one screw for the cover, unplug the connector for the paddle, remove the white part. i ground a paper clip to use to release the wire just be genital. LOL. so much better this way.
Anyone have pictures o how to do this still? The link is dead :(
you can google it, the best thing i did to my car so far
Originally Posted by SK360
(Post 1581563580)
I'll try to get it reposted in the next couple of days. --Dan |
(Post 1581564725)
I thought I had lost everything after a site change and a couple of computer changes but was just able to find the pictures and write-up I had archived.
I was driving the other day and thought about doing something like this. I can't wait to see the DIY! Thanks Dan.
Updated Web Page
I'll run this off my home computer where it will remain available.
http://www.bratten.org/C6/Paddle/index.html Let me know if I missed anything and I'll get it updated. --Dan :cheers: |
That is an awesome write up. Thank you. This will make using the paddles so much better.
Thanks for the repost, much appreciated
Completed this Mod tonight, hardest part was pushing the springs in holding the airbag....love it now, just like my Camaro.
Btw 2012 GS. |
I'm thinking about doing this mod and have a couple of questions for whomever. First, after this is done it has no effect on either thumb "push" on both paddles, correct? (So essentially there are 3 up shift ways, and one downshift. Am I right?? ). Ideally I would like left side, either push or pull, to downshift and right side, push or pull up shift. If that's not possible then this will do, I just want to know.. Also, in the write up it says disconnect the ground located next to the fuse box, but isn't that the positive?? Thanks guys.
it just reverses the operation of the right paddle. you will love it. super easy to do. yes you are right about the battery, just disconnect the neg. terminal and you will be fine.
